Old 08-05-2015, 07:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior
Print Wikipost
Just replaced the infamous Recirculation Door in 30 minutes :-)
Old 10-25-2014, 12:20 AM
RAM Tough 2006's Avatar
RAM Tough 2006
RAM Tough 2006 is offline
Default Thank you all
Originally Posted by chrisbrn2000
Just replaced my recirc door on my 03 Ram truck, it was a pretty easy job except for the back screw on the motor, good thing i had a flexible extension screw driver that made it much easier to take off the motor.
First of all thanks for the instructions on the fix. Worked in fairly short time. Yes, the flexible extension screw driver was another big save.
  #42
Old 10-30-2014, 10:30 PM
Squints's Avatar
Squints
Squints is offline
Can you bypass the heater core and still use the A/C? I need to wait to fix all the doors until i have the funds to get a new dash since mine will be destroyed when i go to take it out to change the doors and heater core
  #43
Old 05-24-2016, 06:17 PM
mkov608's Avatar
mkov608
mkov608 is offline
Fixed my brother's truck today; took less than an hour. Thanks for the post!
K
  #44
Old 05-31-2016, 09:06 AM
xroller's Avatar
xroller
xroller is offline
I also need to change this, thanks for the write up.
Subscribe.
  #45
Old 07-27-2016, 11:44 AM
Hockey momma's Avatar
Hockey momma
Hockey momma is offline
Default Clarification
My 2010 Ram is creating cold air but won't blow on any setting, or barely blows. Not even defrost. Tried heater. Same issue. Think it's still the flap causing the issue? I can hear the motor speed increase but little air flow.
  #46
Old 07-27-2016, 04:30 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Could be a blend door. Could also be a cabin filter if the newer trucks have them.
  #47
Old 07-28-2016, 03:15 PM
DodgeCares's Avatar
DodgeCares
DodgeCares is offline
Hi Hockey momma,
Have you had a diagnostic performed on the vehicle to see what the problem may be?
Kori
Dodge Social Care Specialist
  #48
Old 07-28-2016, 08:39 PM
66three83's Avatar
66three83
66three83 is offline
The door has broken and fallen off. It is resting on top of your fan and blocking the airflow.
  #49
Old 06-11-2017, 06:56 PM
matthewbridges71@gmail.com's Avatar
matthewbridges71@gmail.com is offline
Default Still no resolution to AC vent issues
This is great info thank you! However...with the same symptoms....followed the precise pics and details...it was not the door. All the same symptoms all have summarized..but not the filter ( does not come equipped)..door is intact and actuates...blower in proper function. So...riddle me this...blows slightly....cold when set on AC...actuator door properly set and working...blower in full function.... But still...no resolution. Thoughts?
  #50
Old 06-13-2017, 10:50 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,174 Likes on 2,927 Posts
Drop the fan, and have a look inside. With no filter, it may just be a clogged up evap core.
Quick Reply: Just replaced the infamous Recirculation Door in 30 minutes :-)
