Start Me Up...
As far as the stereo is concerned..the stereo is ONLY on when the truck is. When the truck is on acc, the stereo is wired to not come on. I've had this truck since October, and only found this battery issue causing a pain since about mid-march.
Battery got its charging...was able to start it while the battery charger was still connected, and didn't show any problems once the battery charger was disconnected from the battery terminals. Ran a few errands that didn't include turning off the truck then got to a friend's house down the road from me. Turned the truck off...all is good...then go to leave and it won't start. Same situation as shown in the video. My friend used a volt meter, and read 10V from the battery (mind you, this is within an hour of taking it off the charger) My buddy jumped me, only taking one try to turn my truck on, and I came home..
My thoughts exactly.. This is the second time it's been fully charged, started the truck, then failed to start it a second time a short time later.
Look.....please change the battery. Borrow or steal one (no better not do the later lol) but put another battery on there.
That's the much easier way to see if your original battery is no good.
You can recharge a defective battery and all appears good. But when you put a load on it or return to start your truck, if there's one or several defective cells it will discharge with no parasitic drain at all and not have enough charge in it to turn the truck over.
Al.
Al.
Al.
Al.
Al.
Al.
It's worth the $80+/- to change it, and know for sure.
As far as my understanding is, the battery has be purchased to be hooked up to a customer's vehicle.
