Check Gauges light comes on and RPM's go to 0 while driving
Old Jun 27, 2013 | 10:41 PM
curtislichtenwald6's Avatar
curtislichtenwald6
Default Check Gauges light comes on and RPM's go to 0 while driving
I have a 2008 Dodge Ram Laramie 1500 5.7 L Hemi
So back in February I was driving home from work and all of a sudden I see that my check gauges light comes on and then....all hell broke loose. Everything on my dash went to 0 (RPM's, oil...etc) The steering locked up so it was making it hard to turn. My truck was slowly coming to a stop and there was nothing I could do about it, luckily I could move the steering wheel just enough that I could get to the side of the road. All I did was restart the engine and it worked perfectly fine. A month or so after this happened it did it again, but it hasn't happened since. Any help is appreciated.
If you need anymore info just let me know.
Old Jun 28, 2013 | 07:04 AM
gcburkett's Avatar
gcburkett
I would suspect the PCM or a poor connection to it. I would probably just pull and reconnect all the connectors to the PCM and see if the problem returns. Good luck on this one though.
