3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
just a guess. the throttle plates are dirty. some spray cleaner is not expensive. my dad had a saying about trouble shooting. 'look ad the easiest and cheapest things first."
I cleaned them I've been told so many things could be wrong and now i have to jump it off to start it up could a battery cause the problems I'm having?
Yes a battery can cause this issue. Have it checked. Don't just check the voltage on it with a meter, but have it tested under a load. Most auto parts places can do this for you.
Yes the engine light is on the engine runs rough the rpm gauge fluctuates and if it gets below 1000 rpms it stalls so I've got to hold the gas down to keep it running
