Help!!!
That's next on the list. Drive shaft might be hitting a head shield or something under there....
Get the Entire Truck up in the air with someone in the driver seat and you under the truck, have the person inside put it in 1st gear and just let off the brake and let the truck turn the wheels.
You should then look for any issues with the driveline. BE CAREFUL AND I TAKE ZERO RESPONSIBILITY IF YOU HURT YOURSELF!
Next thing I'd do with the whole truck in the air is turn the steering from lock to lock and see if anything is binding or popping.
Then I'd check endlinks on the sway bars (aka stabilizer bars), and then I'd begin checking the power steering rack.
