Abs and parking brake light on
Did you try the key trick and get any codes?
I'd guess you bumped one of the sensor connections. If you have them up front, they should have a connector around each knuckle, and one in the back that I think is supposed to be on top of the diff. Unplugging an ABS sensor will throw those lights up.
