Shock replacement procedure
So I've been searching the interwebs and can't come across a video or write up on how to change the shocks on my 2008 2WD 1500. Is it the same basic procedure as the 3rd gen 4x4s? Also I got my new shocks (ES9000s) from 4 wheel parts and I called to confirm they sent me the right size for my 6" Fabtech lift and when I hold them up to the Fabtech shocks the Pro Comps are bigger. Will this be an issue with installing or will it just make it ride differently? Thanks guys!
For some reason I thought we had struts...but I looked under there and it's just a simple shock inside the coil spring.My shop manual says to support the truck on jackstands,remove the tire,and support the lower control arm with a jack.Then remove the 3 shock nuts,and remove shock from the bottom.Install in reverse order.Much simpler than I had thought.Let us know how it goes.
Yeah. I don't think you can use ramps as there the shock exits through the bottom, the ramp would be in the way. I have a set of ramps that are like new because I never use them. I always use my floor jack and since my truck is lifted (high enough), I don't need anything to change my oil.
Yea I just park in a sloped parking spot to do my oil so it drains more. But yea in all the videos I've seen for the 4x4s no one uses ramps. I'm still debating on removing the wheel vs just turning it as I've seen both done also and they took about the same amount of time. The shocks came straps on to hold them compressed so I think I'll try to keep those on as long as I can since I've heard trying to compress them is a bitch and a half and I don't want to juggle compressing them and trying to screw back in the bottom bolts. But it looks like a straightforward process I just wanted to be sure before I went at it. I'm probably gonna attempt it tomorrow as today I'm doing touch up painting since some random ******* keyed my truck twice in a 3 day period.
Trending Topics
Exactly^^^^ and you change these out just like you would change shocks on any number of cars or trucks with shocks...so you shouldn't need a video if you've ever replaced shocks before. I don't see ramps getting in the way since your tires will be sitting on them and not restrict the old shocks coming out one bit. Personally I used a floor jack and took the wheels off and did the job in less than two hours for all four shocks. With the wheels off you can see quite a bit better if you are working from the side.
