2007 dodge ram 1500 gear swap ??ss
Ok guys I'm pretty new to the gear and pinion swap along with the axle swaps so ima try and fill you guys in my situation the best way I can.
First and foremost I recently bought a 2007 dodge ram 1500 4.7 flex fuel 4x4 stock gears are 3:55.
Tires I'm running are 37x13.5x20 with a 6" RCX lift.
NOTE: there is no LSD
So the question is it worth buying a LSD and putting the 4:56 gears in that I want, or is it possible to swap my 1500 axles our for the 3/4 ton axels or maybe even the 1 ton axles?
I've done some reading up I coulnt really find anything that helps. So any input would be appreciated good or bad lol thanks for reading.
James
James
