Neutral Safety Switch bypass
truck won't start, fuel pump not coming on gauges won't work but the indication lights come on, on the dash. The little square box around PRND21 is no longer visible. Heard from individuals on the internet that this solenoid pack on the valve body can go bad and it is usually the neutral safety switch. I have already taken the solenoid pack out once. If the NSS is bad I will replace it but I want to test it first.
