Radio static after heater core replacement
2002 dodge Ram 1500 heater core started leaking. Took dash and steering column loose and moved back to replace heater core. Now everything is back and working good except the radio has static. Sounds like ignition static because it changes with engine speed. What might I have pulled loose and not put back to cause this? Sure don't want to remove dash again
