Torque spec for camshaft position sensor install
Old 09-16-2014, 02:32 PM
subzero32's Avatar
subzero32
subzero32 is offline
Default Torque spec for camshaft position sensor install
Title says its all. I'm a stickler for torque specs when available but I do not have this one. Thanks fellow Ram fans.
Old 09-17-2014, 12:18 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
TORQUE - FUEL SYSTEM - EXCEPT DIESEL
DESCRIPTION
N-m
Ft. Lbs.
In. Lbs.
Accelerator Pedal Bracket Mounting 12 - 105
Accelerator Pedal Position Sensor Bracket-to-Battery Tray Bolts 3 - 30
Crankshaft Position Sensor - 3.7L 28 21 -
Crankshaft Position Sensor - 4.7L 28 21 -
Crankshaft Position Sensor - 5.7L 12 - 105 (+/-20)
Camshaft Position Sensor - 3.7L 12 - 106
Camshaft Position Sensor - 4.7L 12 - 106
Camshaft Position Sensor - 5.7L 12 9 105 (+/-) 20
Engine Coolant Temperature Sensor - 3.7L 11 - 96
Engine Coolant Temperature Sensor - 4.7L 11 - 96
Engine Coolant Temperature Sensor - 5.7L 11 - 96
EVAP Canister- to-Bracket Nuts 8.5 - 75
EVAP Canister-to-frame bolts 34 25
Fuel Filler Hose Clamp at Tank 3 - 30
Fuel Filler Housing-to-Body Screws 2 - 17
Fuel Pump Module Lock Ring 54 40 -
Fuel Rail Mounting Bolts - 3.7L 11 - 100
Fuel Rail Mounting Bolts - 4.7L 11 - 100
Fuel Rail Mounting Bolts - 5.7L 11 - 100
Fuel Rail Mounting Bolts - 8.3L 12 - 105
Fuel Tank Mounting Straps 41 30 -
IAC Motor Mounting Screws - 3.7L 7 - 60
IAC Motor Mounting Screws - 4.7L 7 - 60
Leak Detection Pump Mounting Bolt 8.5 - 75
Map Sensor Mounting Screws - 3.7L 3 - 25
Map Sensor Mounting Screws - 4.7L 3 - 25
PCM-to-Mounting Bracket Mounting Screws 4 - 35
Power Steering Pressure Switch - 3.7L 14-22 - 124-195
Power Steering Pressure Switch - 4.7L 14-22 - 124-195
TPS Mounting Screws - 3.7L 7 - 60
TPS Mounting Screws - 4.7L 7 - 60
Throttle Body Mounting Bolts - 3.7L 11 - 100
Throttle Body Mounting Bolts - 4.7L 12 - 105
Throttle Body Mounting Bolts - 5.7L 12 - 105
Oxygen Sensors 30 22 -
Ignition Coil Mounting Bolts 11 - 100
Quick Reply: Torque spec for camshaft position sensor install
