No High Beam on driver side
I recently try to hook up some off road lights on my 2006 ram 1500. I tied the lights into the high beam wire on the headlight bulb on the driver side. When I connected my off road lights there was a spark and now the high beam on my driver side doesn't work. The low beam works perfect. I changed out the bulb but still no high beam. Is there a fuse or have a fried something. I read somewhere that if I unhook the positive cable on the battery then the computer module will reset itself. Any ideas.
No Hi beam Head Light
I have no hi beam headlight on my drivers side. I have a 2006 dodge ram 1500 and I am being told its the ITPM. What exactly is this and where is it located. I think they are referring to the fuse box under the hood. When I check I don't see any fuse there for the headlights. There is a module separate from the fuse box that has wires from the headlights going into it. I think it has 3 or maybe 4 plugs going into it. Would this be the module they are talking about. Also can I just splice wire from the other headlight and run power to the driver side hi beam from the passenger side headlight.
