2006 1500 4.7L 4x4 Cranks But wont start
I have a 2006 ram 1500 that cranks over very fast but will not start. I had this problem last week and the fuel pump was working but it would not start up. I disconnected the battery for a couple of minutes and then it started like normal. Not today. It cranks over no problem but wont even attempt to fire up. I don't think I can here the fuel pump kicking on either. I thought my fuel pump was bad but I sprayed some starting fluid in the intake and it still wouldn't event attempt to start. The only trouble codes I get are one for an oil pressure sensor and one for a thermostat problem but they do not pop up every time and I have had the same codes in the past and never had problems starting. I'm thinking I might have more than one problem on my hands but really could use some help troubleshooting.
I'm sorry to learn of your no-start concern. You mentioned the vehicle did start after the battery was disconnected. Have you recently replaced the battery? Is the battery fully charged?
Here is some information from the Service Manual on a no start condition. Hopefully this helps.
1. Weak battery 1. Charge or replace as necessary.
2. Corroded or loose battery connections. 2. Clean and tighten battery connections. Apply a coat of light mineral grease to the terminals.
3. Faulty starter. 3. (Refer to 08 - Electrical/8F - Engine Systems/Starting - Diagnosis and Testing) .
4. Faulty coil or control unit. 4.(Refer to 08 - Electrical/8I - Ignition Control/COIL, Ignition - Removal) .
5. Incorrect spark plug gap. 5. Correct as necessary.
6. Dirt or water in fuel system. 6. Clean system and replace fuel filter.
7. Faulty fuel pump, relay or wiring. 7. Repair or replace as necessary.
The battery is fine. I disconnected it for 2 minutes and reconnected it and it started just like normal last week. I then drove it normally for a week with absolutely no problems at all. Went up town for a fire meeting (I'm a volunteer firefighter) and when the meeting was over I tried starting and it would just crank over but would not even attempt to start.
Your crank sensor will cause delayed starting. turn the key on/off 3 times and see if it displays a p0335 code. if that code pops up then you need to replace your sensor. I had this same problem after i installed my new engine.
here are the steps i took to fix it:
1. I cleaned both terminals and made sure they were attatched firmly
2. Replaced the cable that goes from the battery to the starter. (the truck started after i replaced the cable but still took about 10 secs for it to start up)
3. Once truck started i let it run for a little bit and get to temp then turned it off and did the key trick to display trouble codes. p0335 popped up which is the crank sensor.
4. replaced sensor and truck now starts up in about 2-3 secs.
Trending Topics
