lost in wyoming
Old 10-20-2014, 01:18 PM
djwood1655's Avatar
djwood1655
djwood1655 is offline
Default lost in wyoming
2006 dodge 3500 103435 miles sat for a year drove it will not shift out of 2 changed tran filter still not shifting ? I am lost
need to get this truck going my job depends on it please help
Old 10-20-2014, 02:11 PM
jkeaton is offline
Dodge Forum Administrator
Moving to the correct section. Welcome to DF.
Old 10-21-2014, 04:32 PM
Izero's Avatar
Izero
Izero is offline
Which engine and we're assuming it's an automatic transmission right? Also, dual rear tires or single?
Any DTCs present (Check engine light codes)? If so, what are the codes...
The truck sat for a year, so there's likely some engine issues that might be forcing it into Limp Mode, so more information you can provide the better....
Old 10-22-2014, 02:28 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Definitely need to check it for DTC codes
Old 10-22-2014, 10:59 AM
djwood1655's Avatar
djwood1655
2006 dodge ram 3500 5.9 automatic trans dual rear tires
Old 10-22-2014, 11:36 AM
Izero's Avatar
Izero
Izero is offline
Any trouble codes that you can report?
Also, we're assuming you put a NEW battery on the truck right? If not, put a new battery on it and see if that fixes the problems you're having.
Old 10-23-2014, 07:52 PM
Mlj1111's Avatar
Mlj1111
Mlj1111 is offline
Your governor pressure has to be monitored with a scan tool. In drive stopped the governor pressure should be 0 psi and as you start accelerating the pressure should rise. Use a scan tool along with a pressure gauge hooked to the governor pressure port on the right side of the transmission then compare to make sure the sensor is working properly.
Governor solenoids are the most common part that fails with these 42/44/46/47/48re transmissions. Replace the solenoid along with the sensor if found faulty. They are easy to replace you just have to pull the pan off to replace.
Another thing it could be is a sticking valve in the valve body and the only way to repair it is to replace the valve body or have it rebuilt by a professional.
Mike
Quick Reply: lost in wyoming
