Shifting out of overdrive
Yesterday 11:58 PM by 14flhxrider
I just bought a 2004 dodge 1500 crew cab 4wd. 5.4 magnum. It has 170k and I'm having an issue with the transmission down shifting out of OD at times. I stop and turn off then start back up it stops doing to for a while sometimes the rest of the day. I've replaced the relay fuse and I had the transmissions check and he said it was a solenoid. I was wondering if the OD solenoid was and easy fix or should I have a transmission place fix it?
