Pleae help! Tried everything! Stumped! 2004 Dodge Ram 1500 hemi
Old 04-17-2015, 08:20 AM
Arod3024's Avatar
Arod3024
Arod3024 is offline
Default Pleae help! Tried everything! Stumped! 2004 Dodge Ram 1500 hemi
Driving down a side road and the truck totally gave on me just stalled when to start her back up and got nothing it cranked but unless I applied the pedal to the floor it didn't do anything just kept Chugging smelling fuel in the air.. When it did start after flooring it, it immediately spit sputtered and died, had it towed in to pep boys they looked at it for hour told me it was not the fuel pump but it was the throttle body based on the engine light code ... I did the job myself not paying pep boys 700 dollars for that! Installed throttle body and new gasket yesterday and still nothing same symptoms! I got codes p2299 p1113 and p0137 any ideas guys I am at a total loss... Just want my truck back
Old 04-17-2015, 10:11 AM
p38251's Avatar
p38251
p38251 is offline
Unhook the battery, to reset the pcm.
Old 04-17-2015, 10:13 AM
HemiLonestar's Avatar
HemiLonestar
HemiLonestar is offline
Reset the PCM, did you train the TB?
Old 04-17-2015, 11:35 AM
Arod3024's Avatar
Arod3024
Arod3024 is offline
No I have not trained the throttle body... I am towing it to the dealership because I can't do that without the scan tool right? ... They can do it there right even if they didn't install the throttle body and it's already on the truck ???
Old 04-17-2015, 11:50 AM
p38251's Avatar
p38251
p38251 is offline
No you don't need scan tool.
Old 04-17-2015, 12:07 PM
Arod3024's Avatar
Arod3024
Arod3024 is offline
Then how do I set it up why won't it run
Old 04-17-2015, 02:21 PM
p38251's Avatar
p38251
p38251 is offline
Un hook positive and negative battery cables. Leave them touching for 5-10 minutes. Do a Google search on the throttle body re learn.
Old 04-17-2015, 05:23 PM
Gone Fishin's Avatar
Gone Fishin
Gone Fishin is offline
check the fuel pressure, regulator may have seized
Old 04-28-2015, 09:28 AM
Northern Goat's Avatar
Northern Goat
Northern Goat is offline
Ths is and contines to be an old wifes tale. This only applies to 2500/3500 Rams but not the hemi's. Training the TB that is.
Old 04-28-2015, 11:57 AM
HemiLonestar
This statement doesn't make any sense...how does it apply to 2500/3500's and not hemis lol? Up until 2008 the hemi was the only engine with an electronic throttle body...TB train is in the FSM specifically for this engine...
Quick Reply: Pleae help! Tried everything! Stumped! 2004 Dodge Ram 1500 hemi
