Driver side brake light and reverse light not working
Try Beech2000's recommendations again. Buying a new socket does not mean that you are getting power to the socket in question. Could be a bad wiring harness, corrosion at the connections, cut wire, etc. Check again with a multimeter or tester, and you will find the bad spot eventually if you work your way back to the battery. It could also be a bad Front Control Module (FCM) which is known to go bad and cause this exact issue sometimes.
