2002 dodge ram 4.7 cooling system conversion
on
It's been a 5 or 6 years since I did this ??? I used Spectra CU 2813 Rad. It is listed for 2004 Hemi. Mounts right up. Maybe some minor hiccup but you can easily figure it out. Also need 2 new heater hoses. I bought fan shroud delete kit from Moe's (not sold any more) made installation very easy. I have an electric fan mounted to Rad and the factory clutch fan and fan shroud has been removed.
Can't post pics on this site. Google "Moe's fan shroud delete kit" for pictures. Or make a post on DT I can post my own pics.
What are you trying to accomplish?
on
Yes you can do that. Rad & rad cap & straight heater hoses are the required parts. In addition you will need an overflow tank. Probably have to do some looking and thinking on that one. Really coolant problems since 2004 that's along time??? It be nice to know what the problem is before spending more $$$$.
Trending Topics
Bought the truck in 04 and was always losing antifreeze from the hose on the degasser bottle neck too much pressure in system I figured. At the time the truck never over heated or ran hot just topped off antifreeze when I lost it. In 2010 drove it to florida from jersey and never thought to check it on the way down and overheated in Jacksonville and blew a hole in radiator. I replaced radiator and was finally going to throw everything at it to find out if I could fix it. I changed everything with cooling system that I could then came the misfire cylinder 3 in 2013 and it was a blown head gasket so I figured this was brewing for a long time. I did the heads at that time and still continued to lose antifreeze. Have changed radiator again with a better one numerous caps 16lb and oe17lb and have tested for hydro carbons but nothing. Oil is clean no water no smoke or sweet smell of exhaust and did try a cooler thermostat. The radiator shop is going to do a pressure test for me and a flush to see if there is any problems. I did notice that Dodge eliminated this type of system and figured maybe it would work better for me.
on
Good Luck
