3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
If you changed your mind, I have a set of extended front shocks with the spacers. I bought them but will not use them after all. PM me if you are interested.
I am not a fan of spacer route. Lots of guys had highway vibrations with them.
You can go with Bilsetin Lift struts(.5"-2" adjustment heights) or Rancho Quicklifts(adjustable from 1/2" to 2.5")
Lift struts keep your stock travel and keep your CV shafts at a much better angle. Nobody with these has had highway vibrations that I have heard of.
2" will set the truck level.
2.5" makes the front higher than the back slightly. Im not a fan of 2.5" levels.
