08 Starts runs 3 sec and dies??
periodically when I go to start truck it starts right up and runs for about 2-3 seconds…..then dies……Repeating this will not change situation. Later the truck just starts. Does the smart key talk to the ignition? Should a "regular" key start the truck as well as a smart key?
on
If you have a chipped key, you need it to start and stay running. If you are trying to run it with a non-chipped key, it will do EXACTLY what you described, start, run for a few seconds then the SKIM shuts it down. If you do this too many times it will lock out your PCM.
My 06 started doing this about a week ago. Starts, runs for a few seconds, dies. I have to turn key completely off, then start it again. Sometimes it takes 2 or 3 times. I tried disconnecting the battery but it is still doing this. Is the battery in my key getting weak? Why wont it "talk" to the receiver? Any help or a direction to start will be great. It doesn't do it every time. It does do it at least once a day though. I also read somewhere that if the truck battery is getting weak, it can start causing weird issues. Any truth to that? Thanks in advance
Trending Topics
