02 Dodge Ram 1500 grinding noise?
Old 07-19-2015, 01:36 PM
shawowzer1981's Avatar
shawowzer1981
shawowzer1981 is offline
Default 02 Dodge Ram 1500 grinding noise?
About 4 days ago I noticed that when I applied my brakes it started making a grinding sound like I was dragging a metal can coming from the rear tires. Brand new tires not even a month old, No wear on the brake pads or rotors. Thought maybe brake calipers? But, it's not a consistent problem when braking it's usually at low speeds and approaching a stop sign or light that it happens. shows no sign of rubbing or rock either. Well last night got my husband (who isn't an expert but has some experience with working on vehicles) take a look and he believes it may be the axle barrings are bad. Okay... going to go ahead and say what my girl brain wants to ask lol.... Is this a bad issue? Can I still drive my truck? What is the worse case scenario if it breaks all together? Will my axle fall off in mid drive on the highway? Is this a common issue? and the golden question.... Is it a pricey fix? Sorry for all the questions but I know a little about vehicles but I don't know much.. hence the reason I sell shoes lol.. Thank you in advance and hope to get it figured out
Old 07-20-2015, 03:51 AM
abarmby's Avatar
abarmby
abarmby is offline
Could be bearing or it could be the rear brake shoes delaminating as has happened on more than a few occasions.
Only way to tell is, to strip and examine the rear running gear and brakes unfortunately.
Its guess work if you dont.
Al.
Old 07-20-2015, 09:12 AM
jkeaton is offline
Dodge Forum Administrator
Pull the drums off and inspect.
Old 07-20-2015, 12:03 PM
abarmby's Avatar
abarmby
abarmby is offline
Quick tip that many people forget to do when pulling the rear drums off.
Make sure you adjust the ebrake through the rear back plate slots, making sure your not adjusting them tight (wheel will lock up and not turn). Rather slacken the adjustment off, so it helps the rear internal ebrake shoes clear the inside of the drum/disc assembly.
No amount of pounding with a sledge will free off the disc/drum without doing this adjustment.
Al.
Quick Reply: 02 Dodge Ram 1500 grinding noise?
