3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I have an issue with my truck, all my lights work fine, EXCEPT the factory trailer plug, lost my left turn signal, right brake light and trailer brakes at the plug......could this be the PDM....FCM ?
cuda 1969,
Could also be the connector.
They are relatively inexpensive to replace if found to be problematic.
Also, try hooking to another trailer with the same style connector as it could help eliminate that as being the issue if it works.
