bad miss at idle please help
hey everyone I'm excited to join this forum. I have an 03 ram 1500 with 150k on it. it has a pretty obvious miss at idle that almost feels like it has a cam in it. I have replaced the plugs and wires, cap and rotor the pcv valve and I did the intake and plenum today because it was bad and I'm still having the same issue. I've done the compression test. checked everywhere possible for a vacuum leak and nothing there. I've tested my injectors and I've checked my spark. everything has checked out good. I've also cleaned my IAC. I am at a loss and I've gotten to the point where dumping a can of gas and throwing a match at the truck would make me feel better. any advice would be greatly appreciated. what stumps me is it was smogged 3 weeks ago with zero issues. the truck runs great over 1k rpm but the second it drops to idle we're chuggin and the truck has a steady shake. this truck is going to make me go broke. lol
compression is good. it has new plugs and wires. I put a new plug in it today and it seemed to help it somewhat. but it still has a slight lope to it. I should add that I have a throttle body spacer and k&n intake on it akso. but I've owned diesels for the last 10 years so this is fairly new to me.
Trending Topics
Did you disconnect the battery when you did your tune-up? By the time you were done, that would've provided enough time for any existing codes to clear. You could buy another plug for #8 and see if that helps.
Go to Advance Auto or similar and get 3 bottles of Chevron Techron gas additive, smaller bottle. Run tank to 1/8 of a tank, pour 1 bottle in tank and fill to a half of tank with super unleaded. Repeat this 2 more times. Drive hard on all these. Fill all the way up with Super Unleaded when these 3 bottles are done.
SJ03
SJ03
