Torque Specs
Torque Specs
I just purchased this truck I tried finding out what service it had done to it. All I could find out was what was on the carfax. TCM & Comp. reprogramed
Now Im planning to service most fluids
Im trying to locate torque specs for the following
Tranny pan bolts specs
Diff. pan bolts specs
type of tranny
spark plug Gap upper .039 Lower .051 is this correct?
Any help would be definitely appreciated...Thanks
type of tranny
Trending Topics
My info from dodge was 15 ft/lbs on the spark plugs for the 08 4.7L. It has aluminum heads but, I don't really think torque is the way to go. Those plugs have sealing rings and the best method for that type of spark plug are quarter to half turn past sealing ring contact with the head. Whats tricky with these heads is having a "good feel" for the spark plug bottoming out against the head which is impossible to visually verify. I'll admit most of my years of experience are on motorcycles but that's my two cents.
I appreciated everyones input...
Im starting on my diff fluid change manual says cover bolts @30 ft lbs
does anyone know if its a one step torque to 30 or 2 step torque 1st to 15 or 20 wait for so long then to 30 ft lbs
The other question is does it mater to warm that fluid up for draining?
Thank you
Thank you
