RTV Gasket maker or gasket
Me personally I don't buy different types of sealants, I only stock Copper Permatex in my tool box. Its great at sealing anything you can think of on an vehicle, even EXHAUST pipes and manifold gaskets!.
I use it on everything, intake gaskets, manifold gaskets, exhaust joints, diff covers, standalone trans pan gasket, plenum gaskets (old 360 Magnums). I've even used it on those old leaky "bypass tubes" on the 318/360 magnum engines without one leak!. I use it in place of Teflon or pipe dope, works great for pipe threading & cooling system taps into turbo chargers & ect. My brother has even used it to seal the cylinder jugs to its block on a 80s 530cc Yamaha snowmobile engine that wasn't worth putting money into for the correct gaskets, 10 years later it still runs without a problem...very much so a believer in Copper Permatex.
I'm sure there are others that do just as good of a job, but I believe the copper works best for many situations because of the coppers thermal properties, and we all know how temperature can rip gaskets apart, plus I have a ton of experience with it and years of knowing what to expect with it. I've taken engines apart that I've sealed with the copper perm and the way the stuff sticks to the parts really gave me confidence that the seal would have held for many years, certainly beyond the scope of what car manufacturers built it to.
Trending Topics
As for leaking, if the surface is clean (I usually prep a surface to be sealed with copper perm with brake cleaner and wipe with blue paper shop towels) you'll never have to worry about leaks. On rare occasions there have been times when I haven't been able to get a surface perfectly clean and it still seals with no problem even with things like gas, oil & coolant residue. Obviously you don't ever want to have more than a residue on it and preferably have it perfectly clean for piece of mind.
Its great all around stuff, when in doubt on which sealant to use, just buy the copper it does it all!.
Is there anything about carb cleaner that I shouldn't use, because I do have that instead of break cleaner. I was going to do it today but I think I will hold off 1 or 2 more days for warmer weather. Im planning to use plastic scraper and soft scouring pad use RTV which indicates apply around all bolt holes and mount plate torque 20ft lbs and wait hr then torque to 30ft lbs. I appreciate everyone's input
Thank you
gary
Thank you
gary
