2006 1500 Hemi clank
Hi everyone. I have a 2006 Ram 1500 Hemi 2WD QCSB. This noise started about a month ago. I can't figure it out. It only happens during coasting and when I'm slowing down and it seems to be in sync with either the driveshaft or rotation of the wheels. If I apply the brakes then it stops. It might also occur when accelerating but I can't hear it over the engine or exhaust. I have a video on YouTube of the sound. Titled "2006 Ram Hemi 2wd Clank". This video was taken at about 15mph. Sorry for the wind. Anybody know what's going on?
Here's a link to the video:
Thanks for the reply. Yeah I checked that. I checked the bed mounts and just about everything that could rattle or shift. At first I thought the u joints could be shot but I changed those and still have the noise. I'm going to check the diff today to make sure nothing is wrong with it. But I don't feel anything physically wrong with the truck when I'm driving. Just the noise.
A side note though. Does anybody know how to diagnose a bad slip yoke? When I was changing the u joints it looked like I had worn teeth. They had a slight angle to them and I figured they would be more squared off. Thanks
Bump
I've been busy with work and school so I haven't been able to chase this problem much. But it is still occurring. I have replaced some worn suspension components and nothing has changed besides my rig handling better. So far I've changed out both UCAs and LCAs, outer tie rod ends, sway bar links, both hub assemblies, both u-joints and had the drive shaft checked for balancing issues. PO took great care of the engine and tranny but pretty much ignored everything else. Anybody have thoughts on what else I can look at? Unfortunately taking it to a shop isn't a real option right now because the cheapest place wants $180 just to look at it. And on top of that the shops in my town are all pretty shady.
New symptom: If I rest my foot on the brake while accelerating then there is no sound. And I mean just the lightest touch. Also when I apply the brakes at any time the sound stops until I release. And the sound doesn't occur for the first few minutes of driving. But starts up after a couple miles on the road, say 4 or so. I appreciate any help I can get and I welcome out of the box ideas. I just want to get this fixed because it's driving me nuts. Thanks
Sorry. I can't get your video to play on my phone for some reason.
I would be looking at your brakes rotors and drums...my guess from your latest post. When you slightly apply brakes you are taking some slack up in the system. i.e. caliper float and pad to rotor clearance
By chance do you have a brake pulse when braking indicating warped rotors? How are the spring retaining clips for the brake pads? Just some things for you to think about. I'm only guessing but would focus on brakes. You could try switching pads and or rotors to opposite side as a test and see if noise changes.
Hate to be That Guy, but $180 is less than the sum of all the money you've thrown into it with those other parts hoping to cure the problem by now. Spend the money, get it diagnosed, then fix it yourself if it is something you feel comfortable doing.
I agree with Dogman -- sounds like something with your brakes (my first thought reading your OP, as well).
Trending Topics
Do you have any suspension mods?
