Clicking sound front drivers side
06 2wd ram 1500
This is really pissing me off. There is new pads and rotors, new wheel bearing/hub assembly/ and new ball joints...
Yet STILL as I am driving at slower speeds there is a click click click almost not as fast as the tire rotates a full rotation. It does it driving on grass too so not a stone in the tread.
Brake pad clips are not hitting rotor. Dust shield has been removed so no stone between shield and rotor.
How can an essentially brand new front end be doing this !!
Please help
Please help
Trending Topics
I never thought of a wheel weight, but with the offset of my rims they stick out pretty far. I'll have to check that out.
I find it hard to believe the original wheel bearing had the same noise then the new one had the same noise and then yet ANOTHER new one had the EXACT same noise. Possible but holy crap that would be rare.
And no you need weight on the vehicle and some speed (5mph or so) for it to start.
When the suspension absorbs a bump it clicks instantly regardless of where it is in its rythmic click click click sequence.
