3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
2days ago it started rain gin so I turned the wipers on. They made a wired sound, and then stopped working. No matter where I position the wiper on/off switch the wipers no longer work...
There's a fuse (F8 30 Amps) and 2 relays, Wiper On/Off and Wiper High/Low In the Power Module next to the battery, I think. I'm not sure about your model, check your Owner's Manual.
I had a similar problem with my 2001 3500. Turns out a simple and FREE fix did the trick on mine. The rear bolt holding the motor to the cowl has the motor ground. I had the wiper motor on the work bench, but cleaning the motor ground brass strap, the bolt sleeve and the under side of the bolt and applying some dilectric grease will ensure a good ground! That worked for me! Good Luck!
