Overdrive issues
Now my truck only does this when it's wet. The tranny rpms will hop all around in overdrive ONLY when it's wet out and will go down to 1400
Trending Topics
It's only doing this when it's wet out though
You never know it could be just a coincidence that it does it when its wet outside. I would say if you're having a surge of any kind get your hands on a different throttle position sensor, or at the very least try to re-calibrate yours.
Are you using cruise control when it happens? Does the speedometer appear to bounce or seem notchy or abnormal in any way when accelerating or decelerating?
You're going to have to check a few harnesses for wetness & corrosion to see if they were compromised. Start with the speed sensor on the trans, then the abs/speedometer sensor on the rear differential. Also check the 2 harness connections behind the drivers side front mud flap. The speed sensor on the trans only gives the pcm a reference of speed for shift points, it doesn't lend any information to your speedometer as only the rear differential ABS sensor does that.
Without driving your truck its kind of hard to diagnose, it could even be a torque converter lock up solenoid. Any more information about symptoms would be great. Take it to a car wash and take a video of the way it runs after.
