Transmission bolt pattern 68RFE on Hemi
Old 08-11-2016, 02:30 PM
hotdawg22's Avatar
hotdawg22
hotdawg22 is offline
Smile Transmission bolt pattern 68RFE on Hemi
Hello all. My question is about the 68RFE transmission that came in the 2014 6.7L Diesel Dodge ram 3500 VS the 68RFE that came in the 2014 Dodge Ram 3500 with the gas 6.4L Hemi engine.
Are the transmission bolt patterns the same. In other words, will the trans from the 6.4L gas Hemi bolt up to the Diesel 6.7L Diesel engine
Thanks and any help will help.
Old 08-11-2016, 07:09 PM
p38251's Avatar
p38251
p38251 is offline
I believe the gas transmission has different internals.
Old 08-11-2016, 09:40 PM
hotdawg22's Avatar
hotdawg22
OK, thanks for reply. I suspected that maybe the solenoid pack was different?? If that is the only problem I could use the one from my transmission that matches my TCM??? I am almost positive that the case and bolt patterns are the same but I want to make sure before I leap as the Hemi trans can be had at a very cheap price.
Maybe someone out there knows the answer. SO tired of this limp mode problem.
Old 08-12-2016, 06:31 AM
hotdawg22's Avatar
hotdawg22
Well, just discovered that the Hemi does NOT have a 68RFE but has a 66RFE instead. So I will just have to drop this thread as there is no way you can use a 66RFE behind a 6.7L diesel engine.
Thanks to all anyway.
Quick Reply: Transmission bolt pattern 68RFE on Hemi
