Bummed after Timing chain replacement-help
I have a 04 Ram with 260,000 mi. It has had a tap at the front of the engine for some time. It was the upper timing chains. The solid guides were gone only the bolt spacers were left. I replaced the timing chains with no problems. I was very surprised how clean the area around the rocker arms and timing chain were as there was NO gum of any kind just oil stain. After every thing was back together it started right up, just one vacuum hose cracked.
I fixed it this morning and started it again and ran it for about an hour and it was running great. I decided to take it out on the road for an easy run to town. (25 miles each way)
I got about 7 miles down the road and the check gauges light came on? All the gauges were good. Then the light cam on again and the oil pressure was 0. It shut off and would not start till it sat some. We towed it home and I went to start it to back it in the garage and it is running rough but will only stay running if I keep the gas pedal down. It does have oil pressure.
I is NOT showing any codes?
What are anyone's thoughts on were I should go from here?
ps I have been doing all of my own work for years and built street racing engines in the 80's, so I do have some back ground with this kind of work.
Still Bummed
I checked all connections and Vac. lines.
Found a crack in one fitting and fixed it.
Then I got a code P0172.
I checked the new plugs and found #7 was wet.
I got a new coil and replaced it, still had the same code.
Then I removed both Oxygen sensors on that side and cleaned and reinstalled them.
Still same code.
Today I replaced the MAP sensor, it took longer but the same code came back.
It runs rough if I keep it above 1500 rpm but any lower and it stops right away.
Any ideas?
Still same code.
Any ideas?
