Flex plate\torque converter bolts
I have a 03 ram 1500 4x4 5.7 hemi. I am pulling the engine to build it up and am to the point where I need to remove the flexplate to torque converter bolts. I cannot find access to these bolts anywhere. There is a plate between the engine\bellhousing that I am guessing is making it not possible to access these bolts. Does any1 know if I remove all the bellhousing bolts will the dust shield\plate be able to be pulled out and gain me access to those bolts? Thanks
What do u mean ? "Though the starter opening"??.... the starter opening is only like the size of a golf ball and u can barely even see just a little bit of the flexplate.....u cannot access the bolts through that hole......u can barely even see but like a half inch of the flexplate.....All u can really see is the teeth of it
Head bolts have oil on them
Okay so I have another question. I have the engine out of my truck and was removing the heads and noticed that 2 of the head bolts on the driver side head had engine oil on them when I pulled them out...only 2 of them..what would cause this? Is it normal? I only have one head off so far. Haven't took the passenger side head off yet to see if any of those have oil on them...any help would be greatly appreciated.thank u
