How many quarts of tranny fluid after solenoid swap
Old 01-21-2017, 05:27 PM
shanes76's Avatar
shanes76
shanes76 is offline
Default How many quarts of tranny fluid after solenoid swap
How many quarts should it take in a 45rfe after changing the solenoid block and both filters? Before changing it registered about 1/2 inch below full mark. Approximately 7 quarts came out, just seems like a lot. Truck was at operating temp in neutral, went thru all the gears, it's a 2002 ram 1500 4x4
Old 01-21-2017, 07:03 PM
p38251's Avatar
p38251
p38251 is offline
5-7 qts is about right
Old 01-21-2017, 07:40 PM
shanes76's Avatar
shanes76
shanes76 is offline
I have 7 1/2 in right now, still not full lol is it possible that some came out of converter when it was low before I did the swap, it was stalling on me because the tc was staying locked
Old 01-21-2017, 09:08 PM
p38251's Avatar
p38251
p38251 is offline
It depends on how long you let it drain. May take a little more
Old 01-21-2017, 09:43 PM
shanes76's Avatar
shanes76
shanes76 is offline
I let it drain till nothing more was coming out, I haven't drove it anywhere so I'm going to check again in the morning
Old 01-22-2017, 10:47 AM
p38251's Avatar
p38251
p38251 is offline
So maybe a little more. You may need to drive it to make sure fluid is up to temp.
Old 01-22-2017, 06:39 PM
jfotsch's Avatar
jfotsch
jfotsch is offline
Last time I changed mine out I left it to drain overnight and I had bought 3 gallons of mopar atf+4 and the 2 filters for the change. I just went to see how much I had left over to answer your question. I have most of 1 gallon left over (6-7qts)
I added a Mag Hytec trans pan too so it added a little bit but I really don't think it added much. It was more for ease of draining before dropping the pan plus there should be some cooling effect due to the finned aluminum.
So it took over 8 quarts if you let it sit like I did.
I remember being very careful not to overfill and ran it on several short trips to get it up to temperature and one thing I was told is very important is filling with the frame level. I have a factory 2 1/2" rake and have to allow for that when checking my oil and transmission levels. I also understand it is better to be just barely over the line and not below.
Hope this helps!
04 Ram 1500 Hemi 4wd QCSB, OEM off-road 17's, BFG-LT's, Airraid Cai, Cortex 3950, Magnaflow y-pipe, Detroit TT, Mag Hytec trans and rear diff, SRT A-pillar w/autometer trans temp, 190 t-stat, pwr stop drilled/slotted all 4, pwr wire, grnd TB
Old 01-23-2017, 04:21 AM
shanes76's Avatar
shanes76
shanes76 is offline
Ok thank you, mine has a 4 inch lift, fairly level, I got 7 1/2 in now, it drained for over an 2 hours, I'll check it after driving home from work today, thank you
