Old 08-05-2015, 09:49 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Guides
Print Wikipost
Which fuse is it to reset the computer??
Old 10-06-2006, 10:36 PM
Dire Wolf's Avatar
Dire Wolf
Dire Wolf is offline
Default Which fuse is it to reset the computer??
Old 10-07-2006, 12:34 AM
kharding20's Avatar
kharding20
kharding20 is offline
Default RE: Which fuse is it to reset the computer??
Just unhook the battery for a couple minutes.
Old 10-07-2006, 02:44 AM
dirtydodge02's Avatar
dirtydodge02
dirtydodge02 is offline
NO NO NO!!!! DON'T UNHOOK THE BATTERY!!! All that will do is **** you off while you're trying to reload your settings on your stereo. Ok, what you do is:
1)Pop the hood and open the fuse box.
2)Remove the ECM fuse (should be fuse 19).
3)Get in and buckle your seatbelt (this will prevent the seatbelt reminder chimes from initiating).
4)Turn the key to "RUN" but DO NOT start.
5)Wait 5-6 seconds and you should hear a chime and then within 1-2 seconds, a second chime will sound.
6)The computer is now reset.
7)Replace fuse and button it all back up.
Old 10-07-2006, 03:55 PM
kharding20's Avatar
kharding20
I didnt lost any stations when I unhooked my battery. Must have been lucky
Old 10-08-2006, 05:49 AM
Remmy's Avatar
Remmy
Remmy is offline
This might be a dumb question but what's the difference between the ecm fuse & the pcm fuse. Becasuse when I installed my K&N I pulled out the pcm fuse (fuse # 23). I don't know but maybe the fuse numbers changed between years?????????
Old 10-08-2006, 12:07 PM
kenihemi's Avatar
kenihemi
kenihemi is offline
ecm or pcm, same thing. In our dodges is called a pcm, powertrain control module.
Just remove the top to the fuse block and look up the number for the pcm fuse
Old 04-14-2019, 09:51 AM
Joseph Rowand's Avatar
Joseph Rowand
Joseph Rowand is offline
Default Please help
How do I do a hard reset on ecu for a 2012 Ram 1500 St 4.7L?
Old 04-14-2019, 10:06 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
Disconnect the battery for an hour.
Old 06-14-2020, 09:03 PM
Matthew Sheintul's Avatar
Matthew Sheintul
Matthew Sheintul is offline
Default What happens if you only hear one chime?
​​and then within 1-2 seconds, a second chime will sound.
Thanks
Old 09-05-2022, 03:41 PM
Unknown ID's Avatar
Unknown ID
Unknown ID is offline
Default Dodge Journey 2014 fuse
My 2014 also has 2 fuses with pcm/tcm on them.
Should I leave those alone?
Trying to reset computer
Quick Reply: Which fuse is it to reset the computer??
