Install writeup: 2wd coil spacer leveling kit
Old 03-26-2009, 01:39 PM
umbighouse's Avatar
umbighouse
umbighouse is offline
Great write-up, thanks. You're not the 1st person to note that the actual height gained is more than the advertised size. I'm wondering about a 1/5" vs 2" leveling kit for my 2007 Dodge Ram 1500 Quad SLT (2WD). I read somewhere that a 2" kit may not fit, and that a 1.5" kit is recommended. Obviously, I would prefer the 2" kit.
Any insight?
Anyone have any pix of a 1.5" leveling kit? Thanks in advance.
  #22
Old 03-26-2009, 04:26 PM
mpfoote's Avatar
mpfoote
mpfoote is offline
The Ford Expedition shocks worked out PERFECT. I have my nice smooth ride back. On the top, they bolted right in. On the bottom, I had to open the holes up with a die grinder because the bolt pattern was skinnier. I then used the stock nuts and some large washers and everything bolted on fine. I went and got and alignment a few hours ago and it rides absolutely perfect now.
  #23
Old 03-26-2009, 04:29 PM
mpfoote's Avatar
mpfoote
mpfoote is offline
P.S. To answer the question of the previous post. I used the 2" spacer kit and the actual measured lift is 3". I thought it would settle some, but I have been driving it like that for a week and it still measures 3" higher. I'm going to do a 1" block in the rear to even it back up.
  #24
Old 04-01-2009, 11:30 PM
gonzzo23's Avatar
gonzzo23
gonzzo23 is offline
I got the same spacer have been getting prices at shops to get it put on but after reading through the post a few times think I will be able to get it done probably this weekend depends on my buddy if he is working are not. I bought the Blistien HD's those should work for better travel?
  #25
Old 04-02-2009, 07:05 AM
mpfoote's Avatar
mpfoote
mpfoote is offline
Just make sure than when you put them sided by side to the stock shocks that they are 2" longer.
  #26
Old 04-02-2009, 07:22 AM
umbighouse's Avatar
umbighouse
I ended up ordering the Daystar 1.5" leveling kit. I called a 4x4 shop and they quoted me $125 for the install. My local Dodge dealer said they will match that, so I'm having them installed by a dealer for $125. The kit itself was $39.99. Not too bad.
  #27
Old 04-02-2009, 09:26 AM
theHemiBeast's Avatar
theHemiBeast
theHemiBeast is offline
Hold up, am I understanding this right....you put on the 2" spacer and now you need a 1" block in the rear to make it even??? So, right now, your truck has a higher front end? Man, I just bought the 2" spacer and I def do not want my truck to be uneven (in the reverse)!!!
Can you confirm/clarify?? If you had to do it over, would you have gotten the 1 1/2" spacer instead??
Thanks!
  #28
Old 04-03-2009, 09:16 AM
mpfoote's Avatar
mpfoote
mpfoote is offline
Thanks!
It is dead even right now, BUT I pull a boat on a trailer trailer a lot and I don't want it to look busted while it is pulling. P.S. the 2" spacer gives you darn near 3" of lift. It did for me anyways.
  #29
Old 04-14-2009, 01:41 PM
ftwproductions's Avatar
ftwproductions
ftwproductions is offline
To Patrick(TXST8tj the topic starter),Thanks for your great description.
That's very usefull!
I ordered the same 2"spacers and it was a piece of cake.It took me about 4 hrs,without anyhelp,yeah my wife tried to help me with the spring but at the end I did it alone with help of some other toolssee pic very usefull )
I did not use a pitman arm puller(just a hammer) or the spring compressor(worked excellent with the big crowbar.)
I also installed a set of Bilstein shocks,the normal ones for a 1500 2wd,and I have no problems with it so far.
Only it's still not level....... It looks like the rear Bilsteins raised the back around 1"
greetings
Joey.
  #30
Old 04-16-2009, 12:54 AM
raminator08's Avatar
raminator08
raminator08 is offline
how much did you guys pay for new shocks? $40 for the lift sounds good but theres still the springs
Quick Reply: Install writeup: 2wd coil spacer leveling kit
