DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 3rd Gen Ram
3rd Gen Ram 2002 - 2008 Rams
Thread Tools Search this Thread
Old 06-26-2007, 02:49 PM
pakaalbite pakaalbite is offline
Default Low idle
i have an 05 ram 1500 with the 4.7. Recently, it has been idling what i thought to be low at 600rpms. Two times in the last weed my truck has shut off when i am pulling in my drive at idle. Is this common with other dodge owners or what needs to be done to fix this? Its still under warranty but id like to know what was wrong before i take it to the dodge dealer so i can tell them whats wrongs so they dont have to spend time troubleshooting.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-26-2007, 05:05 PM
theHemiBeast theHemiBeast is offline
Default RE: Low idle
I have an 07, and my truck idles at 600, sometimes 500 RPMs. (Cross my fingers) I haven't stalled.
__________________
2007 1500 QC - Inferno Red
Yeah.........it's got a HEMI!
Old 06-26-2007, 05:24 PM
bigjrussell bigjrussell is offline
Vehicle: 2006 Dodge Ram 1500 4.7L 2WD RCSB
I'm hitting up some lunch here in about 10 minutes, I'll see where mine idles at. That will at least tell us if it is the assumed low idle or something else causing your truck to stall out.
__________________
'06 1500 4.7L SLT RCSB 2WD
Inferno Red Crystal Pearl
K&N Air-Charger FIPK
Nitto Terra Grapplers 265/70/R17
Old 06-26-2007, 05:33 PM
nathan h nathan h is offline
I have a 97 dodge intrepid and it acts the same way. It idles fine until you are driving and get ready to stop and then it wants to drop below normal idle and die. Another member told me that it could be a vacuum leak/egr clogged/iac motor bad. Check the vacuum lines and make sure they are connected properly. Pull off the egr hoses and clean them good. If this doesn't work replace the iac motor.
Old 06-26-2007, 05:40 PM
Cactus's Avatar
Cactus Cactus is offline
Vehicle: 2007 Ram 1500 SLT Regular Cab with Hemi
Location: Huntersville, NC Living In The Heart of NASCAR.
My '07 did that just the other day. It was hot out and the a/c was on and she idled at 600rpm which felt low. I need to see where sheidles now because I have not noticed it since. Anyone else know what idle speed should be? Red
__________________
2007 Ram 1500 SLT Regular Cab 4x2 w/ 8' bed
Electric Blue Pearl, Hemi, Trailer Tow Package
Melanoma survivor Twice
Old 06-26-2007, 05:54 PM
Just got back. Start-up idle was at 900 RPM and then after warming up and having the AC on it was at about 650-700 RPM. Don't know what it tells you, but mine hasn't died yet.
__________________
Old 06-26-2007, 07:45 PM
tampakenny tampakenny is offline
Vehicle: 2002 Ram 1500 QC 4.7 2wd
I have an '02 with the 4.7 and mine had that issue from new. It actually stalled a couple of times when at a light in traffic downtown! I found a TSB about it and had the dealer reflash the computer. That seemed to work for some time, but now it's getting back to the low idle situation. It'll drop to 500-600 or so, and sometimes dip lower and almost stall, and it is noticeably running low. A quicktap of the gas gets it to settle back where it belongs, or atleast where it "feels" like it is idling smoothly. I can't pinpoint exactly when it is doing it (cold vs. hot, etc.). Otherwise, it runs like it always did. Maybe there is a TSB out for the '05.
Old 06-26-2007, 09:54 PM
NJMandCEM NJMandCEM is offline
Not sure if this helps out.... But I had an 05 1500 with the 4.7... and it always idled low... around 500-550.... Had it at the dealer**** a couple times... and there conclusion was that the computer was just tryin to stay within emissions by burning a lower idle... But i have since replaced that truck with a 07 Hemi.... Which i would'nt say a bad thing about other then it does'nt have a towing package and can't keep itself clean.....It also after the warm up period it does idle at about 500 as well... But if you come across a fix... I'd like to know... .can't waste anymore time sittin in a lot of newer then my truck trucks...
__________________
Love your Truck...
It's all you've got...
Till the next one...
Old 06-27-2007, 04:15 AM
livetokite livetokite is offline
my 06 hemi idles at 500 rpms with the A/C off, with it on it idles around 600. when it hits 500 it normally has a vibration, which i dislike.
when i took it to the dealership for a recall i asked them to higher the idle, they said they did, but it's still the exact same.
i've never had it stall, not once. not even a stutter. but i dislike the vibration at 500
[align=left] [/align]
__________________
Dodge Ram 1500
5.7L Hemi
Nav
Sirius radio
Flowmaster 40 series
Single in dual out
Side exit infront of rear wheel
Old 06-27-2007, 05:23 AM
Maui_808 Maui_808 is offline
isnt there an idle screw?
__________________
1986 dodge ram D150 4x4, Locker in the Rear, 318 motor with headers, 4spd standard trans, edelbrock intake and carb. 5 inch susp lift. 33x15.50 TSL Swampers on 15x12 inch alcoas.
Coming soon...
3 inch more lift
Tags
1500, 2006, 500, doge, hemi, idle, idles, low, ram, rough, rpm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
