line level converter after the amp i built my own fiberglass enclosure lifted the rear seats 3 inches and shoved 2 12inch jl w6s i got alot out of that set up but most people adding a sub to factory amped systems dont realize u need signal after the amp or sometimes it ends up real quiet i mean u might be alright oin some cars but i dont recomend it go after the amp
you get enough airspace/magnent room for those w6's under your seat? I have two perfect w7 10"s in my shop, cant use them because i want my back seats...they are about 4 or 5 inches too deep it seems
w7s are much deeper then w6s at my shop we jacked up my back seats and got the room surprisingly but now i was gunna do a custom box for 1 12w7 i dont see y u couldnt do a 10 maybbeeeeee 2 if u have a 40 20 40 bench seat in the front pop out the middle compartment and make a custom box jl makes a stealthbox there for 1 10 w6 but they rnt pushing the boundaries do 1 or 2 w7s pm i believe i still have the papers on that box at my work
I have that one, picked it up on ebay for 60 bucks. It gives you front and rear outputs plus a remote turn on for the amps.
I also have the foxbox, ( i love it) it is crazy how much bass you can create with the right speaker/amp. I have to open my windows or the sound presure is unbearable in the cab.
they say that there is screws, but its a lie...just grab the lower left corner with a rag (itll cut your hands) and pull off working around... i need to order that foxbox
You were correct. Thanks for the rag tip, it was on there really tight. The holes were there, but no screws like you said. New unit (RAQ 6 disc MP3 unt) works and sounds great for only $165.00 from Epay.
so if you want to keep everything stock, and add subs just get the box, subs, amp, wirekit for amp and speakers, and a line converter. i just got done doing this, i wired the line converter into the back door speakers, and then from there you have your pre-amp out puts and all you have to do is run the remote wire from the lighter outlet that turns off with the key, then run your power and ground wires, and hook the subs up to the amp and then your done. i have 2 10" memphis subs, rockford amp and capacitor, they work and sound awsome
