DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 3rd Gen Ram
Thread Tools Search this Thread
  #21
Old 01-13-2009, 08:20 PM
Ilovemytruck Ilovemytruck is offline
2004 Dodge Ram 1500
Vehicle: 2004 4.7L Dodge Ram
PLUG & PLAY 8-10RWHP in less than 60 seconds. The POWER WIRE will be the quickest and easiest mod you have ever installed. Reports of .5 to 1 MPG have been reported under easy driving conditions.
Details:
The POWER WIRE will fit:
Fits all 2000-UP 3.7L, 4.7L, 5.7L & 5.9L engines
Works with ANY/ALL stock or aftermarket induction system
May also fit many other 2000 to present Dodge vehicles
*NEW* The =POWER=WIRE=> Now installs on these new vehicles:
2005 Dodge Magnum RT
2006 Dodge Charger 3.5L V6
Add reliable 8-10RWHP to your new Dodge in little as 1-2 minutes of your time!
We will only list them as we learn if they fit or not... If you purchase the Power Wire for your Magnum or Charger or ANY Dodge product and it does NOT fit send it back for a full refund. Im betting the PW will fit all MAGNUM and CHARGERS.
The =POWER=WIRE=> Is a PLUG & PLAY mod that will give you 8-10HP with less than 1 minute to install. Advancing the timing for increased HP is an old trick that has been used for many years. With the newer computer controlled vehicles there are no distributors to adjust, so to gain additional timing advance we need to alter the signal from the air temperature sensor for the desired advance. Your PCM uses the Air Temperature sensors to help control timing and Air/Fuel ratio.
Your O2 sensors keep your Air Fuel ratio nailed to 14.75:1 at all throttle positions except Wide Open Throttle (WOT) so the POWER WIRE can NOT cause you to run rich during normal driving because no matter what the AFR will be 14.75:1. For this reason The Power Wire has been reported to add 1-2MPG increase when driven lightly. But at WOT the Power Wire will add approximately 2.5% at WOT. When your at WOT you are more concerned with HP than MPG at that moment in time and while passing an additional 8-10RWHP is exactly what your looking for.
The POWER WIRE should not be confused with the "E-bay Mystery Mods" that just claim to give you HP without any explanation as to how that particular mod works... But we try to equip you with the information you need to make the best decision for your performance quest.
When installed the POWER WIRE alters the signal to your PCM making it think the intake air temperature is 20 degrees cooler than the actual temperature at "ALL TIMES". This timing advance is worth approximately 8-10RWHP
The POWER WIRE has been reported to richen the AFR by one full point at WOT, this is good if you have long tube headers and other mods that tend to lean out your AFR at WOT. Installing the POWER WIRE can help cure this lean condition.
So does this sound like the same thing you purchased?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #22
Old 01-13-2009, 08:26 PM
lxman1's Avatar
lxman1 lxman1 is offline
Caliber forum Moderator
Dodge Forum Moderator
2008 Dodge Ram 1500
Vehicle: 2008 QC Ram BigHorn Hemi
Send a message via AIM to lxman1
Quote:
Originally Posted by lxman1 View Post
Wow, 100hp for $22!! I'll buy two and have over 545hp. plus over 30mpg!!!! Right up there in Viper territory.
Here is a more realistic version http://www.airram.com/product.php?ca...6&productid=21
It is safe, just fools the PCM into thinking the incoming air is colder than it really is and richens the mixture a bit. Harmless to your engine. If you want one, By the one in the link.
__________________
2008 RAM 1500 Sunburst Orange QuadCab BigHorn. 5.7L HEMI
2009 Caliber SXT Sunburst Orange
  #23
Old 01-13-2009, 09:10 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn SeVeReDiStOrTiOn is offline
Vehicle: 2007 RCSB
You have to give it to the guy...he knows how to market a product.
And I wouldn't say it's safe...the IAT also helps adjust timing along with fuel when the intake air temp increases.
__________________
-07 RCSB 2wd 5.7-
Magnaflow muffler, Airaid MIT, Predator 87 Tune
  #24
Old 01-13-2009, 09:20 PM
Hoss356's Avatar
Hoss356 Hoss356 is offline
Vehicle: 08 1500 QC 4X4 hemi
$30!!!! Sooo... let me get this straight, You paid 30 dollars for something that sells on ebay for 20? Plus you're pissed that it didn't work? Have you sent any money to Nigeria lately? I here they'll cut you a check for $MILLIONS$ if you sent them 2,000 dollars! You're just mad because you finally realized you're an idiot, do the world a favor don't have kids, and in the meantime stop sniffing paint chips!
__________________
2008 1500 Hemi 4X4- Magnaflow cat back, Diablo Sport Predator 91 tune, Airaid MIT intake, 265/70r17 BFG AT KO's(gotta sick deal on em), Hella 500's w/silverstars, Go-Rhino steps, Bushwhacker Bed Rails, Mopar rear wheelwell liners, OEM mud flaps, Rain-X wipers , K&N air filter, Phillips +80 headlights and a barefoot gas pedal!
  #25
Old 01-13-2009, 10:23 PM
SmokeySportRam's Avatar
SmokeySportRam SmokeySportRam is offline
2002 Dodge Ram 1500
Vehicle: 2002 Dodge Ram QC 1500
Quote:
Im thinking you told him, I bet he doesnt come around much after he reads the replys and see that nobody is on his side, and hes an idiot
__________________
  #26
Old 01-13-2009, 10:33 PM
dodge it then ram it's Avatar
dodge it then ram it dodge it then ram it is offline
Vehicle: 03 Ram 1500 QCSB 4x4
Damn you guys are harsh. Glad it wasnt me that bought it!
__________________
03 QC 1500 Ram 4x4 5.7 V8
K&N CAI 37x13.5x18 FC-II 18" Procomp 1059
Magnaflow Dual Exhaust 3" P.A. Body Lift
146,000 plus miles and still running strong!
  #27
Old 01-13-2009, 10:44 PM
Redone4x4's Avatar
Redone4x4 Redone4x4 is offline
Vehicle: 04 QC HEMI 4wd
Send a message via Yahoo to Redone4x4
creating a user profile just to post this was the first warning sign, I think.....just my $.02 lol.
__________________
"towing with 3.55's is like pedaling a bicycle into the wind"
Silver Truck Club Member #1 2004 4x4 QC 5.7 HEMI
6" fabtech lift, 315/70/17 BFG A/T's on some eagles, TrailFX tube steps,limo tint
  #28
Old 01-13-2009, 11:30 PM
Hoss356's Avatar
Quote:
Or he could be chatting amongst us and created a fake profile to conceal his identity.... So... Which one of you is it?!
__________________
  #29
Old 01-13-2009, 11:37 PM
ried69 ried69 is offline
2003 Dodge Ram
Vehicle: 2003 Ram 1500
Most people just get mad to realize that they got ripped off. It's nothing hereditary, and there's no reason to be that mean about it. If you ever got ripped off, would you want someone to run up and kick you in the balls, and say it's so you can't procreate since someone was smart enough to steal some money from you. Does that sound fair? No, and people like that should be reported, there's no reason that they should be allowed to scam on internet, and for people to know that and just brush it off.
__________________
  #30
Old 01-14-2009, 12:10 AM
Hoss356's Avatar
I apologize if I'm coming off callous, but I'm not gonna tip toe around the tulips for a grown ass man who's crying like a little B--ch with a skinned knee over something so minor. Life ain't sugar coated and if you can't take something small in stride then you'll never handle the bigger things... like kids, who look up to adults for guidance on how to react to different situations.
__________________
Tags
03, 2008, 47, blower, chart, cummins, diesel, dodge, dyno, ford, freedback, mind, mindblower, performance, ram
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
