DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 3rd Gen Ram
Thread Tools Search this Thread
Old 03-02-2009, 11:16 AM
sabin420's Avatar
sabin420 sabin420 is offline
1995 Dodge Neon
Vehicle: 95 NEON, 03 RAM 5.7 HEMI
Question converting 2wd into 4x4
I ran into a problem today. It snowed in GA. Me and a bunch of my neighbors don't have 4x4 trucks and can't make it out of the neighborhood due to a large hill. The few that had them could easily make it. Well, I would like to know what I would need to convert my 03 HEMI QC 2WD into a 4X4. Any information on where to find these parts cheap would be helpful also.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
03 Ram 5.7 HEMI cold air intake, Cat Back Dual exhaust
95 Neon with all the fixins minus the Turbo
12.5:1 Compression N/A Tuned
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-02-2009, 11:22 AM
bdhuntr's Avatar
bdhuntr bdhuntr is offline
Vehicle: 2005 Ram 1500 QC 4x4
The cheapest route would be to sell it and buy a 4X4.
__________________
2005 Ram 1500 QC 4X4 4.7 L; Airaid CAI, Flowmaster 50 SI-DO exhaust; LT285/70R17 BFG AT/KO's w/2" torsion bar crank; st/steel nerf bars; Bully aluminum billet fuel door
Old 03-02-2009, 11:30 AM
sabin420's Avatar
1995 Dodge Neon
Yeah, but you don't really find that many at the dealerships down here unless they are new. I just got mine last year $8000 and still making payments. It's a great truck and has a lot of engine mods done to it already. And it's in my favorite color...dark blue.
__________________
Old 03-02-2009, 11:38 AM
bdhuntr's Avatar
Quote:
Getting everything you need will probably be pricey. And a lot of work unless you're into that type of thing. Try doing a search. There may be some info already on this site about doing that.
__________________
Old 03-02-2009, 11:45 AM
traker1001 traker1001 is offline
Vehicle: 2005 Dodge Ram 1500 BigHorn
It's a Long difficult process and will probably cost you more than the difference you would probably pay.You are better off selling and buying a 4x4, or even buying another vehicle that has AWD or 4wd just for times like this. FWD cars should have been able to make it up to.
As far as RWD trucks go on streets, I have been able to make it just about anywhere a 4wd can (On the streets). When I got slippery hills I would lower the tire pressure, Put as much weight over the rear axels as you can and take it slow.
With all that, One thing I have seen, 4x4 tend to have more aggressive A/T or M/T tires where as RWD seem to usually have straight street tires. I have always had A/T tires on my RWD truck which make a huge difference in traction in snow and ice.
To shorten the whole thing, Between tires and driving style,You can usually get anywhere on the streets a 4x4 can.
__________________
Old 03-02-2009, 11:48 AM
sabin420's Avatar
1995 Dodge Neon
I got a full shop in my garage at home, lift, compressor, all the specialty tools and all. I've been building racecars for me and my friends. So doing it is not the problem.
I've already been searcing for information. I know how to convert the driveline, my main concern is with the suspension and brakes. I know I'll need:
Differential, Drive Shafts, Front Axel, front hub assy.
Maybe I can solve the suspension question by buying a lift kit and putting that on. and brakes, maybe go to a larger 4-6 piston setup.
__________________
Old 03-02-2009, 12:01 PM
oefootball_70's Avatar
oefootball_70 oefootball_70 is offline
2005 Dodge Ram 1500
Vehicle: 2005 Dodge Ram 1500 4.7
let me know how it goes. I know there is a guy on the dakota section that turned a 2wd into a 4wd. NOt sure how he went about it.
__________________
Motive 4.56 Gears, CAI replace the hat, flowtech glass pack, Towing mirrors,
Recon Cab Lights, tinted tail and 3rd brake lights, Rough Country 6 inch lift,
Goodyear MT/R's 305/70/17's , and 2 KC 6" lights behind the grill
Old 03-02-2009, 12:14 PM
SeMiGoD's Avatar
SeMiGoD SeMiGoD is offline
2007 Dodge Ram 1500
Vehicle: 07 Dodge Ram 1500 QC Hemi
Why not look around junkyards for a wrecked 4X4 truck and strip it clean.
__________________
A Bunch
Of Extra
Black Stuff
Old 03-02-2009, 01:07 PM
Second on SemiGods suggestion. As far as the suspension goes I beleive the difference between the 4wd and 2wd drive is the 4wd has the torsion bars. Maybe instead of stripping a older, maybe you could look into the 06's and up, Getting the parts and fabbing them in would probably be easier using the 06+ parts.
Also, keep an eye on the gear ratio's, You don't want to get a donor with a different ratio unless your gonna change the gears.
BTW, take pics and show off your progress, I would love to watch it happen. Hell, If I lived by there I would offer to bring the beer and help.
**Edit**
Hey I had the thought, Since you are changing the front, Why not put a solid front axel from a 2500 in it, I think the widths are the same.
__________________
Old 03-02-2009, 03:05 PM
Ridinhigh Ridinhigh is offline
2004 Dodge Ram 1500
Vehicle: 04 Ram 1500 QC 4x4 SLT with the HEMI!!!
if you want an easier route you could put an lsd in so that both back tires would work for you instead of just one and put some AT or MT to help with traction and you should be fine for the select amount of snow you get but if you do go with conversion +1 on the SFA they are much better to put in good luck man
__________________
Tags
2wd, 3500, 4wd, 4x2, 4x4, axle, changing, convert, converting, dodge, make, making, ram, ramcharger, solid
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
