2006 ram 1500 33,000mi. shakes at idle, hesitates,carbons up. I had full tune up, injector cleaning x,s 2 no error codes. the dealers "3 of them" says well there is no error codes bring it back. on my own changed the pcv valve. no help.
Does anyone know . need help
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Reason: misspelled
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Has any of the dealers given a thought to check the throttle body? If it's dirty it will give your symptoms and often not generate a CEL.
Also, does the oil pressure needle stay constant or does it dip down low and then come back up. This would indicate sludge and possibly a clogged screen or sending unit, again, this does not often generate a CEL.
Both are known issues that can cause your problem.
__________________
4.56 Gear Club Founding Member
Yes, that is a gun in my pocket and No, I am not happy to see you!
I have dont know if they checked the throttle body after cleaning. but the oil pressure needle is normal range, does not move. when the engine is cold it runs perfect.warm the idle drops to 500 shakes
when at warm driving temp. is when the problem happends 1st,2nd 3rd ok 4th,5th slugs and kicks down. dead peddle.BUT if in tow haul ,or overdrive off ,runs great? 89 octaine works better,
Reason: to add
__________________
2004 4.7 QCSB 4x4SILVER TRUCK CLUB MEMBER #3, Hella 500 Club Member #10 MODS: TGC 2.5" leveling kit, Spectre intake, Coffin Muffler, 12,000 lb Mile Marker, HELLA500 "Just blind the $hit out of people"
