DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 3rd Gen Ram
Thread Tools Search this Thread
Old 06-22-2009, 04:21 PM
mov mov is offline
Vehicle: 1998 Dodge Ram 1500
Will this same procedure work on a 1998 Dodge Ram 1500?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-10-2009, 09:55 PM
motox851 motox851 is offline
Quote:
Originally Posted by Docwhitley View Post
1) Turn ignition to OFF.
2) Locate the Data Link Connector, its a black 16 pin connecter that is under the driver's side dash, right where your right knee would be.
3) Ground pin 1 of the Data Link Connector by taking a wire or paper clip and running it from pin 1 to pin 4. Pin 4 is ground so you can just short pin 1 to 4 and it will be grounded. Grounding pin 1 tells the system you are ready to reprogram it.
4) Close all of your doors.
5) Turn the key to ACC then back off. The door locks will lock/unlock. This is the signal that the system is ready for reprogramming.
6) Push a button on your remote, doesn't matter which button.
7) If you have 2 remotes, then press a button on the 2nd remote within 1 minute of pressing a button on the 1st remotes. Both must be programmed at the same time. If you only have 1 remote then press a button 2 more times to signal that you only have one.
8) The doors will lock/unlock to signal the codes were received.
9) Remove the jumper wire from the data connector.
Good luck... I think I got everything
I have a 2005 w/ the same problem. Did this method work for anyone? I went to do it and realized that pin1 is blank. I looked it up on the service manual and it is supposed to be blank, so it's not just my truck. Therefore, I don't see how connecting a ground (pin4) to nothing is going to do anything. I was going to try other pins, but I'm not real excited about grounding out various pins. Any advice would be appreciated.
thanks
__________________
2005 Ram 1500 QC, 4.7l / 2004 Durango 5.7l / 1992 Jeep YJ 4.0l
"Without Struggle, There is no Progress"
Old 11-03-2009, 09:10 PM
missouriman missouriman is offline
my pin one is blank also.
assuming that it is the upper left pin hole.
so any other things to try/do before I go to the dealer.
I do not have an original key bob.
Old 11-03-2009, 11:42 PM
HemiLonestar's Avatar
HemiLonestar HemiLonestar is offline
2003 Dodge Ram 1500
My Garage
Vehicle: 2003 Ram 1500 Lonestar Edition
Send a message via AIM to HemiLonestar Send a message via MSN to HemiLonestar Send a message via Yahoo to HemiLonestar
Go to Dodge.com to the owners section and download an owners manual.
__________________
Sarcasm - it beats killing people...
2003 Ram 1500 QC Hemi Lonestar Edition
2004 Jeep Liberty 3.7 4x4
Old 11-04-2009, 09:59 AM
I have the owners manual.
the re programing is only IF you have an original working key bob.
I would not need to buy one if I had one.
I tried the other ways mentioned in this tread, but no luck there.
do you have a link for the shop manual?
it is a 2002 2500 ram with the ctd.
thanks for trying.
Old 11-04-2009, 12:10 PM
espinosafell's Avatar
espinosafell espinosafell is offline
Vehicle: 2004 Dodge Ram 1500
Your going to have to go to a dealership or know someone with a DRB tool
__________________
2004 Dodge 1500 QC 5.7L
Tags
05, 1500, 2003, 2005, cummins, data, datalink, dodge, keyless, link, pin, program, programming, ram, remote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
