DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 3rd Gen Ram
Thread Tools Search this Thread
Old 04-04-2009, 12:10 AM
turbospeed440 turbospeed440 is offline
Default Spark Plugs
Hello all,
After searching on here on how to replace and install the spark plugs in my 05 ram hemi pick up. I decided to make my own post since I couldnt really find a post that answered all my questions.
So here they all are.
To replace the the plugs is not a really hard job but not an easy one as well.
Easy would consist of a Honda civic. I think my mom could change those.
Hard would consist of a porsche 911 turbo.
The first thing you are gonna need are if u have a dual plug head is 16 plugs. Now ill give my two cents on this.
The factory ones are Champion. They are good but would keep them in my snowblower. why, quality control. if you blow a snow blower engine its only a few hundred. My truck engine is a lot more. Try selling champion to Porsche or BMW. Now i would suggest platinum ones only because they last longer. Plugs that are copper tips will start to wear out as soon as you install them. and for a few bucks more a plug get the better ones.
But you can get any plug you want as long as they are the correct gap (.045) and heat rang.
I started with the passanger side first.
here are the steps I took.
1. Remove the airbox cover and airfilter 1 hose clamp on airbox.
2. Remove the breather hose from the cover and disconnect the air boot attached to the intake. one hose clamp.
3. Remove the bottom half of the airbox. it just pulls out.
4. Now start by removing the coil packs. I found that if you use a 1/4 air rachet makes it easier to remove the packs. I also found it easier to disconnect the power lead from coil packs. I found it easier to open the plastic clamp that holds the heater hoses next to the last cylinder and push the hoses out of the way.
5. Now use a 3in extension and standard sparkplug socket attached to a 3/8 air rachet to remove the plugs.
6. Once all are remove and replaced just reverse the order and install the coilpack and airbox.
7. The drivers side is a bit harder.
8. The front two cylinders are easy.
9. The back two i found work really well if you use the 1/4 inch air rachet and standard 10mm socket to remove the coil packs. You can remove the vaccum line that attaches to the brake booster to give you more room if you like. I did.
10. Once the packs are off if u drop in the spark plug socket first then the 3in extension and use the 3/8 air rachet it works easy. I found you might have to crawl into the engine compartment to reach but im short. When replacing the plugs just drop in the socket attach the extention and use the airrachet.
11. Once all the plugs are in just replace the coil packs and reinstall the vaccum line. Thats it.
It took me about 2.5 hours to replace all 16. That was with people calling and stoppin by. I hope this all helps out. I will include pics in the next few days.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
05' silver quad cab, slt, daytona editon, 20's, apperance package, oh ya HEMI.
Super charger on order.
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 04-04-2009, 12:23 AM
ramhunter9's Avatar
ramhunter9 ramhunter9 is offline
Vehicle: 07 MEGACAB HEAVY HALF 4X4
Send a message via Yahoo to ramhunter9
ok im going to bite my tounge on this one...... see guys i can controll the anger
their is nothing wrong with champion copper plugs if they were bad the manufacture would not have used them . they are a 30k plug and are cheap . the hemi engin does not like expensive plat plugs for some reason.
your post is informative on the install but your theory on plugs smells like dog $hit
__________________
2007 MEGACAB 4X4 HEAVY HALF 4:10 GEARS
Old 04-04-2009, 12:26 AM
Alpheus Alpheus is offline
1998 Dodge Ram 1500
My Garage
Vehicle: 2003 Dodge Ram 2500
You beat me to it. DONT BUY THE HIGH PRICED PLUGS!!! Champion or NGK Work great. Also I do not agree with using an air ratchet for install.
Old 04-04-2009, 12:38 AM
Redone4x4's Avatar
Redone4x4 Redone4x4 is offline
Vehicle: 04 QC HEMI 4wd
Send a message via Yahoo to Redone4x4
i tried buying platinums from my stealership, who loves to make money off us people, and they would only sell me stock champions. and, there is plenty of info on champions on here.
__________________
"towing with 3.55's is like pedaling a bicycle into the wind"
Silver Truck Club Member #1 2004 4x4 QC 5.7 HEMI
6" fabtech lift, 315/70/17 BFG A/T's on some eagles, TrailFX tube steps,limo tint
Old 04-04-2009, 12:41 AM
Redone4x4's Avatar
and...not everyone here uses air tools. i do, but most dont have access to them. so some might not understand exactly how u did it.
__________________
Old 04-04-2009, 02:04 AM
lxman1's Avatar
lxman1 lxman1 is offline
Caliber forum Moderator
Dodge Forum Moderator
2008 Dodge Ram 1500
Vehicle: 2008 QC Ram BigHorn Hemi
Send a message via AIM to lxman1
Hemi's require a copper core plug. They like hot spark. Platinum is not as good of a conductor and although it last longer, does not spark hot enough. If you would have looked in the FAQ sub-forum, you would have seen the write-up on the older (with plug wires) Hemi plug changes
http://dodgeforum.com/forum/3rd-gen-...-5-7-hemi.html
__________________
2008 RAM 1500 Sunburst Orange QuadCab BigHorn. 5.7L HEMI
2009 Caliber SXT Sunburst Orange
Old 04-05-2009, 11:17 AM
bigHildom's Avatar
bigHildom bigHildom is offline
Vehicle: 05 Dodge Ram
Default platinum are the way to go
I think you all have good info on here. But if i was going to replace my plugs i would use a platinum plug they last last twice as long and they burn cleaner. But thats just my opinion and i'm only saying that because i just went to a tranning seminar on spark plugs last week. They even used the hemi motor as an example, the only reson dodge put the coper plug in the hemi was it cost them half as much and hemi owners are truck people, and tuck people like to change there plugs.
Old 04-05-2009, 11:30 AM
ramhunter9's Avatar
Quote:
well aslong as you went to a "seminar" on spark plugs you are now a lic mechanic right ?and we should believe everything you say.....well to each there own . i say IMO copper runs better on the hemi 9 out of 10 will agree and we didnt go to seminars we used the produts and tested them.
__________________
Old 04-05-2009, 11:51 AM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn SeVeReDiStOrTiOn is offline
Vehicle: 2007 RCSB
Quote:
Originally Posted by turbospeed440 View Post
Hello all,
I like you already...be aware this site has a lot of champ cheapy nut huggers.
__________________
-07 RCSB 2wd 5.7-
Magnaflow muffler, Airaid MIT, Predator 87 Tune
Old 04-05-2009, 11:54 AM
Vehicle: 2007 RCSB
Platinums also have a copper core guys...it's the tip that makes them last longer/hold gaps longer/resist oxidation longer.
__________________
-07 RCSB 2wd 5.7-
Tags
2004, 30000, champion, change, copper, dodge, engine, hemi, iridium, miles, ngk, plugs, ram, spark, sparkplugs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
