DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 3rd Gen Ram
Thread Tools Search this Thread
Old 05-03-2009, 09:02 PM
sublimedude's Avatar
sublimedude sublimedude is offline
2003 Dodge Ram 1500
Vehicle: 2003 dodge ram 1500 4.7
it u do that non fouler trick where should u place the sensor, how far from the first sensor should u place it? i wanna put true duals on my 4.7 and remove the only cat i have but there also two resinators and one of them have that sensor in front and back of it, its kinda weird
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 05-04-2009, 08:51 AM
HEMi 5.7 HEMi 5.7 is offline
thanks for your comments ..
well the cel was before i took the cats off .. and i checked again after i took the cats and i found that the problem is the egr .. nothing else ..
about the cats you can take them off without the sensors .. i dont now if the 4.7 is the same ..
Old 05-04-2009, 11:55 AM
AhmedRam AhmedRam is offline
Vehicle: 2004 DR QC 4.7L
Quote:
Originally Posted by HammerZ71 View Post
I didn't catch that on my first read, good catch Ahmed.
Im your student HammerZ
__________________
DR 2004 QC V8 4.7 4x4, Front & Rear Night vision cameras & Sensors, Mopar Bedliner, Tonneau Cover & Grille Guard, Side steps, Ipod kit, P-Muffler, MT Baja ATZ 33x12.50, SC Flashpaq 3815, Power Wire, 4.56 Gears, Detroit Trutrac
Old 05-04-2009, 07:55 PM
2003 Dodge Ram 1500
yea i cant find any info on this matter, i put a couple of post up but no one seams to know and i dont wanna waste my money tryin to put true duals on it if its not worth it, or if its even possible
__________________
Old 05-05-2009, 11:12 AM
V10Venom's Avatar
V10Venom V10Venom is offline
Vehicle: 2003 Dodge Ram SLT 4.7 QC/SB
I bet the 3.55 gears are really holding you back. But you should be a lot faster than 10 second 0-60 mph runs. You should be able to kill the stock GM trucks unless they're duramax's. They are nowhere near what a Hemi is. Do these:
Spark plugs
Full Seafoam Treatment
Switch to Mobile 1
Get your EGR Valve Replaced
Fix the problem while its stock and then add performance parts. No point in trying to make a truck that isn't running right fast. Fix it back to the stock point and them make it fast.
__________________
2003 Atlantic Blue Dodge Ram SLT QC/SB
1998 Pontiac Grand Prix GTP Daytona 500
Old 05-05-2009, 11:51 AM
superdak05's Avatar
superdak05 superdak05 is offline
2005 Dodge Dakota
Vehicle: 2005 dodge dakota
my dakota had the 3.55 and switched to the 4.10m big overall difference. as for removing the cats, bad idea. most people will just punch the cat out for a more free flowing exhaust, that way you still have the bung were the sensor will plug into
__________________
thats right i did it ,so what, cry two tears in a bucket, f@#$ it, lets take it to the stage
13.7 / 101.3 in the 1/4 mile
Old 05-05-2009, 12:33 PM
HammerZ71's Avatar
HammerZ71 HammerZ71 is offline
Master of Disaster
Dodge Forum Administrator
2004 Dodge Ram 1500
Vehicle: 2004 QCSB 1500 Hemi 4x4
Send a message via AIM to HammerZ71 Send a message via MSN to HammerZ71 Send a message via Yahoo to HammerZ71
The cats used on the Hemi Rams are among the most free flowing stock converters in the industry, besides a little back pressure is essential for good low end torque to get you rolling from a dead stop easier.
There is no need to remove the cats. I put on LT Headers and simply moved the cats back about 18" to allow for the extra length of the headers, extending the sensor wires by about that much.
I've done the non-fouler trick in the past when I've cut out the cats, but these newer cats are not your father's '70s vintage, highly restrictive catalytic converters...
__________________
4.56 Gear Club Founding Member
Yes, that is a gun in my pocket and No, I am not happy to see you!
Old 05-05-2009, 01:31 PM
truckin151's Avatar
truckin151 truckin151 is offline
2005 Dodge Ram 1500
Vehicle: 2005 Dodge Ram 1500 RCSB
0-60 in 10sec?? I would die if that was all my truck could do. What else do you have on your truck? Any large tires or lift? Anything weighing it down? If not take it down and get it serviced, change out all the fluids (oil, diff, trans, coolant), get your EGR valve replaced, and get the plugs replaced. That way you are starting out with new everything and give it a run.
__________________
MODS:......
Old 05-05-2009, 01:54 PM
Cheeech Cheeech is offline
Vehicle: '08 Quadcab 4x4
Yeah, no joke. Platinum has been at an all time high the past few years. the last thing automakers wanna do is coat the inside of the cat with more Platinum than they need to. Costs too damn much. They are using otherways such as 2 plugs per cylinder, changing the positioning of the plugs, redesigning the combustion chambers for more "swirl" action to reuse waste gases....etc..
Change your gears front diff and rear diff $2k+/- and see how it is from there. Gonna be a huge improvement none the less and up the amount you can tow or haul.
Tags
03, 060, 2003, 456, 47, catalytic, cats, converters, cutting, dodge, faster, hemi, make, ram, sublimedudeyahoocom, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
