Youve got to cut the tip off... right past the lip where the pvc inserts into the elbow...
heres a few pics...
Hope this helps... all and all i spent 35 on it... thats with a cheap autozone cone filter and the pvc plus a can of krylon indoor outdoor paint... I figured if i got the high heat paint it would be wasted because the pvc would start to melt before the paint did...
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
Sponsored Links
Registered users do not see this ad. Click here to register for free!
yeah i just plugged the hose with a bolt and screw band... It has a more throaty sound... It does have a little more pep, Im sure if had a throttle body and tuner id prolly have more but for now its got a pretty good response.
Just bought all the stuff for this CAI so here it is. I have a couple problems stho now. My first gear feels like it wants to bog out went i floor it. Then after it gets over like 3 grand it runs strong. Any ideas? Oh two other things i had a qustrion was about was that hose that went to the stock box. what should i do with that ... and their was a ssenser in the hat of the intake what should i do with that?
The sensor I didnt have but Im sure if you drill a hole into the pvc and duct tape it in it should be fine... thats what a few other guys have done... I think you still need to reset your trucks computer... just unhook the battery ground cable for atleast 5 minutes, and then drive around for a few miles like granny... that should let your pc reset the airflow sensor and all that jazz...
Anyone ever try some PVC from the foglight opening/oval grill to pointing up towards the CAI filetr area? I was going to attempt it but thinking it may just turbo charge any water/rain towards that are also?!
seen people use the aluminum piping for a drier. My mind is drawing a blank.
__________________
Motive 4.56 Gears, CAI replace the hat, flowtech glass pack, Towing mirrors,
Recon Cab Lights, tinted tail and 3rd brake lights, Rough Country 6 inch lift,
Goodyear MT/R's 305/70/17's , and 2 KC 6" lights behind the grill
