DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 3rd Gen Ram
Thread Tools Search this Thread
  #21
Old 05-07-2009, 08:21 PM
Black_Beautiful Black_Beautiful is offline
So drillin and puttin that Air sensor back in that will stop the first gear bog? Just at a comeplete stop.. floor it and it bogs after 2k rpms it's fine no problems...
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
:::Big Ricky:::
22's, Custom CAI w/k&n, str8 pipe, 7" flipout Kenwood Touch, Pioneer Tweets, mids, 2 r/f amps w/2 twelves, probox, PS3, BlackTruckMember#420
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #22
Old 05-07-2009, 09:02 PM
chambers's Avatar
chambers chambers is offline
Vehicle: 2004 Dodge Ram 3.7 v6 manual trans.
I don't know it might, that sensor is just so the computer knows the temperature of the incoming air. The pcm/ecm may just need time to adjust to the increased airflow, did you unhook the negative battery cable during the install?
__________________
Silver Truck Club Member #12
Mods: Spectre CAI w/ open trueflow filter, Taurus e-fan, Magnaflow muffler dual-in single-out (factory y gone), Jet stream scoop, jet stage 1, ASP UD pulley, Line-x
  #23
Old 05-07-2009, 09:24 PM
Bigc9164's Avatar
Bigc9164 Bigc9164 is offline
Vehicle: 07 Dodge Ram Reg Cab
make your own. i promise u will be way more proud of it when it is done. and it really is not that hard!!! and mine is holding up great!!!!!! and sounds amazing!!!!
__________________
  #24
Old 05-07-2009, 09:28 PM
Bigc9164's Avatar
drill out the hole then wrap the sensor in electrical tape and screw the sensor in. it will stay. and i would drill a hole for the hose. it is adding power not taking away. don't plug it!
__________________
  #25
Old 05-07-2009, 09:38 PM
Markmm0000 Markmm0000 is offline
Vehicle: 05 1500 5.7RCEB
For the hose that goes from your oil filler to stock air box get a mini spectre filter from autozone(small version of the big one you have) for 10$ and connect that right to the nipple comming off the oil filler. If the nipple is too big I used some of the rubber line from the original breather line to get it to work. As for the censor I grabbed some elelctrical gromits for sheet metal and plugged it with that. Ill take a pic of it in a minute and post it.
  #26
Old 05-08-2009, 11:57 AM
here i mine just finished it yesterday. Got it in white pvc 3" it's half the price of the black. So did a little cuttin some sanding some painting and booooom here it is.. Havn't drove it since yesterday when i was havin whole shot bogs.. After it got going the power was great.. after i installed it i did take the ground off for about 10 min and put it back. Havn't drove it since, Have not drilled trhat hole for the air sensor yet either ..
__________________
:::Big Ricky:::
  #27
Old 05-08-2009, 01:04 PM
V10Venom's Avatar
V10Venom V10Venom is offline
Vehicle: 2003 Dodge Ram SLT 4.7 QC/SB
I really think you need to get that IAT sensor back in and the hose fixed, This should take care of the bog IMO. But it looks good, I'm going to be setting mine up the same way as you did in a couple weeks.
__________________
2003 Atlantic Blue Dodge Ram SLT QC/SB
1998 Pontiac Grand Prix GTP Daytona 500
  #28
Old 05-08-2009, 04:00 PM
Well i just drove it around for a couple hours i do have to say i can tell a dif in my jump and the evilness of the engine. It stoped doing that bog at the start. Runs just fine now. I bet theirs more power in their if i just did a tune up never got around to it yesterday. People want to charge me 150 for just the labor. Could not puttin the hose back in cause any damage? and what about teh sensor will that cause any damage not back in?
__________________
:::Big Ricky:::
  #29
Old 05-08-2009, 05:02 PM
Ok just drove to the store let the truck sit their runin in the parkin lot and when i came back it was over heating. then on my way home drivin it just started to go bck down. Anyone have a clue what that is
__________________
:::Big Ricky:::
  #30
Old 05-08-2009, 06:31 PM
JJn5526's Avatar
JJn5526 JJn5526 is offline
Vehicle: 2008 dodge ram 1500 4.7L V8 Big horn Edition
Send a message via AIM to JJn5526
You absolutly need to make a hole for that sensor, the computer needs to know how cold the air is and how much its getting, without that the computer will make wrong estimates and screw everything up.. as for the pcb rubber tube i just bought a metal peice the same size made a hole in the Pvc pipe and screwed it in there and poped the tube onto it... dont really know what the tube is for but if its on the truck and it goes in the air box it obviously needs to be on there.. so use ur imagination and get that tube in your air intake..
__________________
Inferno Red Truck Club #1! 2008 Dodge Ram 1500 4x4 QC 4.7L V8 Big Horn Edition, Custom K&N Cold Air Intake, Ractiva Oil temp, Water temp, and Oil psi gauges in a tri pillar, Oznium Inferno 2 Underbody LED's, Razonic Halo projector headlights, Silverstar 4100k's in the fogs, Painted Grill, Front and Rear bumpers, Air dam, and Radio bezel.
Tags
1st, 47, air, bog, bogs, cold, dodge, gear, grand, gtp, homemade, iintake, intake, pipe, pontaic, prix, pvc, stratus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
