DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 3rd Gen Ram
Thread Tools Search this Thread
Old 05-15-2009, 03:37 AM
dodge it then ram it's Avatar
dodge it then ram it dodge it then ram it is offline
Vehicle: 03 Ram 1500 QCSB 4x4
Just buy a used rear end, get a mechanic friend if you have one, buy a case of beer, give case of beer to mechanic, have mechanic fix the rear end. Make sure he doesnt drink it till the job is almost done though. Then help him finish the beer. The more you drink then the less you just payed him. LOL!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
03 QC 1500 Ram 4x4 5.7 V8
K&N CAI 37x13.5x18 FC-II 18" Procomp 1059
Magnaflow Dual Exhaust 3" P.A. Body Lift
146,000 plus miles and still running strong!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 05-15-2009, 03:46 AM
abarmby's Avatar
abarmby abarmby is offline
Vehicle: 03 Dodge Ram Hemi SLT sb QC 4x4
Get a used rear end.
Install a new DTT c/w a superior install kit which contains all the necessary new bearings, seals and new crush sleeve etc.
This will make the used rear "like new" again.
With the DTT you will have a bullet proff rear and no more worries.
I replaced my crappy stock LSD with a DTT and I have both peace of mind and a great planted axel.
Here's a pic of my axel and DTT install.
Hope this helps?
AL.
__________________
03 1500 Hemi SLT 4x4 QC sb DTT NGK Iridiums DMH K&N Ranchero's torsion tweak Tints 20's Westins Xenon arches Raider Low Rider tonneau Prinz LPG VSI system EBC brakes LTZ's 3" T304 exhaust 200psi viair 480c Kong train horns leather int 6000kHID&fogs fox box 2x12" dvd 2x9" monitors
Old 07-21-2009, 02:07 AM
DougieFresh1970's Avatar
DougieFresh1970 DougieFresh1970 is offline
Vehicle: 02 Dodge Ram 1500 Quad Cab
Anyone have tips on the kits and tools needed to overhaul my 9.25 LSD trac-loc differential? Im having the same issue with my 02 Dodge Ram 1500 Quad Cab. Ive been driving for about a year with a noisy pinion bearing. On a tight budget all I could to in the meantime is frequently change the axel lube with heavy weight synthetic gear lube in hopes to keep the metal bearing shavings down to a minimum. The first lube change I did of course laying inside on the magnet were those c clips everyone seems to find. I dont believe I need to replace the housing. The only leaking I see is the gear lube out the pinion. Ive had the rear tires off a few times and didn't see any seepage out the axel ends. With luck I may get by without having to replace much more than the seals and bearings. I may replace the LSD trac-loc with the 9.25 12 Bolt Auburn Posi LSD. Ive rebuilt a few motors in the past but this will be a first with an axel overhaul. Thanks in advance. Doug
Tags
925, broken, chrysler, clip, clips, differential, dodge, issues, limited, neon, problem, ram, retainer, slip, symptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
