I am getting a whistling noise from the dashboard area of my 2006 Ram when I hit about 55 t0 60 mph. It is very annoying, but it goes away if I roll the window down a little bit. Any thoughts? Thanks
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Vehicle: 2005 Dodge Ram 1500 With 6" lift and 36" tires
Quote:
Could be air escaping from a door or window that is not sealing right?? Or check to make sure that your rear window is closed all the way. I had a whistle in my drivers door and I had it straightened, problem solved.
with your window closed check to see if you have the whistle with the fan on and off? Just another way to see when it us under a different pressure.
Back window is closed tight, doors also seem to be tight. Noise happens with fan on or off. It seems to be originating from the upper part of the dash concentrated mostly on the passenger side.
Is it a whistle or a high pitched buzz? I was getting a noise like wind blowing across a wooden reed (buzz?)but couldn't figure it out. Happened at 70 mph with a head wind but in the location you are speaking of.
I think I figured it out....the sound appears to be coming from the top part of the windshield. If I press the windshield near the top the pitch of the whistle changes. Now I just have to get it fixed, it drives me insane. Thanks everyone for your responses.
My passenger side just started whistling and its annoying as hell when your going 60 mph, Im thinkin about putting a piece of tape across where the mirror meets the door where it seems to be generating the sound, DAMN it PISSES ME OFF, lol She started doing it after i gave her a good bath, want an ungrateful B*TCH
__________________
Daily Driver - 05 1500 Hemi quad cab, 3.92's, lsd in the rear, 17" Eagle alloy wheels wrapped with 295/70/17 Nitto terra grapplers, Superchips 3865, vararam intake,dynomax cat back, Synthetics all the way around
That is where my brother-in-law thought he heard mine. Next time I'll have someone push on the seal.
