DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 3rd Gen Ram
Thread Tools Search this Thread
Old 07-30-2009, 08:47 PM
sabedra211's Avatar
sabedra211 sabedra211 is offline
Vehicle: 04 ram 1500 4.7
Default My caliper wont come off! I need help :D
I searched and i read its really hard to come off just keep wiggling it off.. But mine just doesnt want to come off! i dontknow what to do? I removed the long caliper bolts but it still wont budge really. There these other two bolts that are like 13/16 they wont budge lol. so is there any clips holding this caliper on? heres a pic of my brakes.. someone please help! thanks!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
2004 Dodge ram QCSB 4.7L 5 speed auto. Stock..
1994 Camaro z28
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-30-2009, 09:00 PM
hontzy87 hontzy87 is offline
Vehicle: 2003 Dodge Ram 1500 4x4
Did you supress the calper piston? you have to let pressure off the piston cause it's still clamped around the rotor...
__________________
2003 Dodge Ram 1500 4.7L/6k HID Heads and fogs/Hella 500's/2 12" RF P3S's w/HB 1200W AMP/American Dash Red dash kit
<img src=http://dodgeforum.com/forum/image.php?type=sigpic&userid=108690&dateline=1258521599 border=0 alt= />
Old 07-30-2009, 09:04 PM
Redone4x4's Avatar
Redone4x4 Redone4x4 is offline
Vehicle: 04 QC HEMI 4wd
Send a message via Yahoo to Redone4x4
with the engine off, open the brake fluid reservoir cap on the master cylinder. You can carefully pry the caliper off going behind the brake pad. the horseshoe areas in your pic. it only takes a little bit to free it up, then it should slide and rotate off.
__________________
"towing with 3.55's is like pedaling a bicycle into the wind"
Silver Truck Club Member #1 2004 4x4 QC 5.7 HEMI
6" fabtech lift, 315/70/17 BFG A/T's on some eagles, TrailFX tube steps,limo tint
Old 07-30-2009, 09:30 PM
Rebeltilldeath3's Avatar
Rebeltilldeath3 Rebeltilldeath3 is offline
Vehicle: 03 Ram
Get a pry bar and dead blow and beat the **** out of it. You're not going to hurt it, unless you start smashing the brake line. Hit the front, hit the back, hit the front, hit the back, etc. etc. You'll break it loose. Take your time and don't be scared of breaking anything, because you won't. I've taken 8lb sledgers to calipers before, no damage done.
Worst comes to worst, take the saddle off with the caliper. The saddle is held on my the other two bolts.
__________________
Old 07-30-2009, 10:40 PM
weedahoe's Avatar
weedahoe weedahoe is online now
Vehicle: 04 Dodge Ram QC
Send a message via AIM to weedahoe Send a message via MSN to weedahoe Send a message via Yahoo to weedahoe
I was also going to say you can get a large screwdriver or small prybar and wedge in the holes in the top of the caliper against the piston and rotor to free it off the rotor. Ive had to do that before
__________________
Link to my mods
Link to my gallery
Old 07-30-2009, 10:50 PM
Vehicle: 03 Ram
Quote:
The caliper doesn't stick to the rotor. It binds/sticks in the saddle. That may have worked that time, but it was a horrible idea. You could have cracked the rotor or damaged the piston.
You want to pry between the saddle and caliper.
The only reason the piston is an issue is it's taking away slack to wiggle the caliper out of the saddle.
__________________
Old 07-31-2009, 12:36 AM
Redone4x4's Avatar
you can do it and grab just the pad and not damage the piston or anything else. I have never had to beat on a caliper to get it free. I also turn the wheel im working on out towards me so i can see a little better when im doing brakes.
__________________
Old 07-31-2009, 12:44 AM
Vehicle: 03 Ram
Quote:
I've had to do it on every Chrysler vehicle I've worked on. Chrysler needs to pay TRW more money to get decent God damn brakes.
__________________
Old 07-31-2009, 01:53 AM
abarmby's Avatar
abarmby abarmby is offline
Vehicle: 03 Dodge Ram Hemi SLT sb QC 4x4
At either the top or bottom of the caliper (depends on which side your doing), there's a small tab that locates underneath the caliper adaptor.
This tab MUST be pushed down/up from underneath the caliper adaptor freeing it.
You can then wiggle the caliper up/down the adaptor, until it's free by using a small pry bar.
MAKE SURE you don't nip/tear the rubber gators fitted around the caliper pistons.
The calipers will eventually come off if you adopt the "rocking" back/forth method previously mentioned.
Spray the entire area with brake cleaner to get rid of a lot of the accumulated dirt/dust/debris before you do this and you will get them off eventually.
As stated, don't be frightened by applying a bit of force with the pry bar. Just work out if the calipers binding or hung up as you go so you don't snap anything, which would be pretty difficult.
Hope this helps?
Al.
__________________
03 1500 Hemi SLT 4x4 QC sb DTT NGK Iridiums DMH K&N Ranchero's torsion tweak Tints 20's Westins Xenon arches Raider Low Rider tonneau Prinz LPG VSI system EBC brakes LTZ's 3" T304 exhaust 200psi viair 480c Kong train horns leather int 6000kHID&fogs fox box 2x12" dvd 2x9" monitors
Old 07-31-2009, 01:59 AM
Bluesmanjesse's Avatar
Bluesmanjesse Bluesmanjesse is offline
2006 Dodge Ram 1500
My Garage
Vehicle: 2006 Dodge Ram Hemi sport QC 4x4
One thing as a side note,I would't leave my truck on a Jack Stand on soft grass for too long. Careful pry bar application between the caliper and the saddle may do it. Two pry bars back to back one acting as a fulcrum for the second one in the gap between the saddle and the caliper has worked well for me in the past.
__________________
Black 2006 Hemi QC 4x4 sport ,Magnaflow 14", Line-X,Rockford Fosgate HE2 12" sub pushed by an RF 500 watt mono amp,Peripheral Ipod adapter ,Polk Full range speakers,Garmin nuvi 255w GPS,SS nerf bars,325/60/18 Terra Grapplers,2" TC leveling kit,18x9 Eagle alloys.Black Truck Club Member #118,Hemi Truck Club member #22
Tags
1500, 1996, 2006, 95, bolt, brake, caliper, calipers, dodge, loose, ram, removal, remove, stratus, stuck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
