Cant figure out how to replace stub shaft on 05 ram
I have a 2005 ram 1500, I stripped my cv shaft and also stripped the "stub shaft" that comes out of the differential. I have the Cv removed and the diff cover off. Im aware that the center pin has to slide out of the way to get the c-clip off the stub shaft to slide it out but i cant figure out how to get that pin or whatever it is backed out so the center pin will slide up. Im stranded in my driveway and cant go to work til i fix this ANY help would be appreciated. THANK YOU! -Aaron powell-
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
05 ram 1500, 4.7, 4x4, 6 speed, 6" inch BDS lift, on 37" BFG KM2's mounted to 17x9 rockcrawlers, 4:56 gears w/Auburn LS rear, K&N 77 series CAI, Stage2 jet chip, TB spacer, Gibson headers and exhaust, Herculined rockerpanels, frame, bumpers, and interior floor :-)
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Well since nobody responded to this post a few weeks ago, I'll answer the question for myself just incase anyone else runs into this problem. There is a "roll pin" or "spring pin" that holds the center pin in place. It comes out quite easily by hitting it out with the correct size punch (i used a transfer punch) from the left side access hole (when looking from the front) I felt pretty dumb after figuring this one out haha.
__________________
