I had a coil code on mine, all I did was disconnect the neg. battery to clear the code then swapped the coil w/ another to see if the code moved w/ the coil. Turned out it was nothing, so give it a try.
__________________
Silver Truck Club Member #12
Mods: Spectre CAI w/ open trueflow filter, Taurus e-fan, Magnaflow muffler dual-in single-out (factory y gone), Jet stream scoop, jet stage 1, ASP UD pulley, Line-x
